DJI RC 2 Clean HDMI Feed
4004 7 2023-12-24
djiuser_S9AP6OzVDBGB
When can we expect an update to the firmware to allow for a clean OSD feed through the HDMI output on DJI RC 2 controller? This is a feature on previous controllers and drones that are discontinued and cost about 4000 dollars
2023-12-24
DJI Gamora
Hi, there. Thank you for reaching out. Please know that the DJI RC 2 doesn't support the HDMI output feature officially. The video output function hasn't been officially tested for stability and reliability, therefore, the clean HDMI feature may not be added. Thank you for your understanding.
2023-12-25
DAFlys
You can use an hdmi to usbc adapter to screen mirror.   Then apply a bit of cropping/zooming if you don’t want to see the OSD
2023-12-25
djiuser_oAfyISnQJlqP
India
We can do this to get clean hdmi feed on DJI rc 2:
Press and hold the C1 and C2 buttons simultaneously on the DJI RC 2 remote controller for about three seconds to toggle the On-Screen Display (OSD) of the HDMI output on or off. By doing this, you can disable the OSD and get a clean HDMI output from the remote controller.
3-25 17:45
tomzb
Czechia
djiuser_oAfyISnQJlqP Posted at 3-25 17:45
Hello, do you have any example or short clip of it working please? We are more than interested but couldnt make it work.
Thank you so much for droppin the info
6-1 02:23
solo16
Flight distance : 1516014 ft
Does this leave the normal flying screen on the controller or also make that a clean feed?
7-23 05:41
erdigoktas
Turkey
Hello,
We are planning to set up a broadcast system for weddings. This system will use 3-4 different cameras, including a jimmy jib, a mobile camera, a fixed camera, and a drone. We have figured out how to connect the other cameras, but we need help on how to transmit the video from our DJI Mini 4 Pro drone to the Blackmagic ATEM Mini. Can you assist us with this?
Thank you.
7-28 01:11
AccXess
Indonesia
Has there been an update on this yet? A cleanHDMI out (via USB C) would be REALLY a great feature...
9-2 02:17
