Manitobahunter
![](https://forum44.djicdn.com/data/attachment/common/c5/common_13_usergroup_icon.png) lvl.4
Going to add yet another bit of info here. So yesterday, after flying around for some time, and the AR homepoint working as it should, I went down over a lake at a couple meters negative altitude from the hill I was flying off of, come back up to a higher altitude, and guess what, the AR homepoint has gone missing. Flew back to my landing pad area, then turned and flew off into to the distance, turn back around after seeing the H reappear on the screens edge and the AR home point has reappeared. I chaulked it up to maybe loosing the GPS lock as I went down low over the lake close to the hill, although no warning popup occured.
Being as I want to figure this out, I went out flying again today at a location with km's of open spaces, surrounded by the occasional mountain or two. This is BC, Canada, its hilly to say the least, and spent some time, cruising around, flying up mountains, swooping back towards my landing area, and all was good in AR homepoint land. And then I went down to 50 meters AGL or so, across an open area, over some trees and into another large open area, we're taking several hundred meters away, and turn around to head back and the AR homepoint is nowhere to be seen. Flew back to my landing area, and flew around a bit and it never re appeared. So I landed, swapped batteries, take off and fly a ways away, turn around and there it is in all its glory, shining its bright yellow H like a beacon to my homepoint.
So while the auto active shots feature seems to consitently kill the AR homepoint entirely until a restart, there seems to be more going on here, as I haven't used that feature in the last couple days.
After reviewing the videos with my buddy Mike, who also has a mini 4 pro, he noticed something interesting. When the H traveling around the displays border should transition to showing the AR homepoint, (H in a circle with a dot), that's when it disappears or should I say fails to appear. As I was approaching my landing pad at about 14 meters away, the AR homepoint flashed on for a second, and the disappeared again. Mikes theory is that the buggy instruction is the transition frame where it should appear as I turn towards the homepoint, (having the H disappear off the edge of the frame and become the AR homepoint), and when the next bit of instruction says it should actually disappear when I get too close to my landing pad and it would normally disappear. (in this case it actually flashes on for a fraction of a second and then goes through its instruction to fade out). What do you think?
