In case you are not aware the OM6 gimbal has a total tilt range of 65 degrees, which makes it hard to do jib shots. You can work around it by rolling left or right, but you have to go the right way or the gimbal will flip the phone on you. I've made a little video that tests how well DJI does against their public specs and shows you how to correctly do a job shot with the gimbal:
Toph101 Posted at 1-3 05:09
Really useful, thank you! I was doing the jib shot straight on and bending my arms as much as possible, but this makes a lot more sense.
