Bashy
Flight distance : 2354357 ft
2ball Posted at 12-30 18:01
Thanks for the info so far.
I did not get a manual with my Drone. I did download the manual in the link in the comments above. In that manual the controller looks to have fold out antenna. I don't think my control has antenna's. Is that right? (Mini2 SE)
Is this your RC?
If so then you probably should have posted in the Mini 2 SE section, not Mini SE section, even though you did mention Mini 2 SE in the post, the Admin didn't pick up on that
You need this manual https://dl.djicdn.com/downloads/ ... _Manual_v1.0_EN.pdf
Most USB-C to USB-C will do if, i was you, make sure it can handle 30w in case you want to charge the RC and drone at the same time.
