DJI Pocket wheel and gimbal failure
342 5 1-2 02:53
nexuscoach
South Africa
Hi,
Whenever I connect my wheel controller to my DJI POCKET, the gimbal rotates upwards and stays stuck in that position.
Firmware is uptodate
Any ideas?
bruce
1-2 02:53
DJI Tony
Hello there. Sorry about the trouble. Have you already tried calibrating the controller? You can swipe down on the screen, tap on the gear icon, enter "Accessory", and then choose "Control Stick Calibrate" to calibrate. Have a nice day.
1-2 20:09
nexuscoach
South Africa
Hi
I have done as you suggested; no luck unfortunately - see video link https://drive.google.com/file/d/1G4oDX_M_avb27rYoPSkhK23lro5wRZdT/view?usp=sharing
please let me have some ideas to fix.
1-5 08:03
fansb3fe41a1
South Africa
DJI Tony Posted at 1-2 20:09
Hi
unfortunately -see video link
1-15 06:31
DJI Tony
fansb3fe41a1 Posted at 1-15 06:31
Hi
Hello there. Thank you for the added video. Is your Osmo Pocket already on the latest firmware? If not please try connecting it to your Mimo app and update it. You can also try resetting the camera. If the issue persists we suggest sending the device for repair. We appreciate your patience.
1-16 01:09
fansb3fe41a1
South Africa
Thanx
Firmware is up-to-date
Where do I send the item from repair, in South Africa
1-16 07:09
