hasansenel60
Flight distance : 413537 ft
Turkey
DJI Susan Posted at 1-19 01:02
Thank you for your reply. Just to clarify, the gimbal behavior you mentioned on the video (0:07-08 and 0:13-0:14) is a normal behavior of the gimbal, because the stick was released suddenly, the gimbal will automatically spring back when it reaches its endpoint to protect itself from reaching its limit.
You are suggested to release the stick gently and avoid a sudden change of speed. Thank you for your attention.
2 arkadaşımda daha var aynı mini 4 pro ama onlarda bu sorun yok neden bu peki? |
