fansd7752764
I made more tests and when the lens return to the "parked" position is unpredictable. Mostly the first time I turn it off after the first power on (when you see the DJI logo), it will not return to the park position.
I don't know if this is more common or is it just my unit.
Also, if it did return to the parked position, the lens will start to rotate freely after a while even as the gimbal is now parked straight. Thus, if you put it in the case and in your pocket, the lens will not be "protected" now.
