Mavic 2 - drone repeatedly disconnecting from RC
260 1 1-10 10:13
jimhallsworth
So my drone hadn't been used for a little while but I need to complete a survey for work. Everything was charged fully before heading to site. Used an iPhone 7 with the RC and was getting repeated disconnections and then almost instantly reconnection. I managed to get the drone up into the air but the disconnections meant I had to abort the flight because I didn't consistently have control.
For the first attempt i was using the RC side USB connection with a DJI supplied cable to a Apple lightning port. I switched this out for an Apple supplied lightning cable using the bottom large USB port and was gettin the same issue.
Today I had another go using my iPad - new generation so has USB C connection - I used two different cables and was still getting the repeated disconnections and reconnections. I updated the firmware, cleaned the USB sockets with an air blower, deleted and re-installed the DJI Go 4 app, re-linked the RC with the drone and re-calibatred the IMU but none of that made any difference.
Two other people I know are experiencing the same issue.
I've basically run out of ideas on how to solve this, does anyone have suggestions or even better solutions!?
1-10 10:13
DJI Gamora
Hi, there. Please know that we've responded to your other post. You may refer to this link. You may let us know about the latest progress.
1-11 22:46
