RC 2 Can't Connect via WiFi
1979 3 2024-1-10
Sulu600
Flight distance : 486634 ft
I am getting an error message for any option
on my  RC 2 that requires internet access.  I have
three different ISP providers and three different
wifi routers/modems.  No matter which I select,
either 2.4g or 5g, still get the same error message.
Function unavailable in Local Data Mode
Here is a screen recording of the error msg and
some of my wifi settings:
https://drive.google.com/file/d/ ... view?usp=drive_link
2024-1-10
DJI Gamora
Hello, there. Sorry for the inconvenience. May we confirm the current firmware version of your DJI RC2? Have you tried to log in and see if it will reject your account as well due to a network error? Please know that your video will be examined for further checking. Rest assured that I'll keep you posted on the latest information.
2024-1-10
Sulu600
DJI Gamora Posted at 1-10 23:13
Hi, thanks for the quick reply.  Current ver. is showing "V02.00.0300" as shown in DJI Assistant 2 for consumer drones.  I have no trouble logging into DJI services on my Mavic Pro  using any and all of the
WiFi connections.  Any time I try to access any information that requires an internet connection I get
the error that I am in Local Data Mode.  I have only flown my Mini 4 Pro once before updating to
the current firmware and the first time all updates for both the drone and the rc2 were done via
WiFi network at my home
UPDATE:  I found a setting under Notifications and Privacy that turns on Local Data Mode and
it appears to be ON by  default.  Turning it off solved my problem.
Steve
2024-1-11
DJI Gamora
Sulu600 Posted at 1-11 16:28
Thank you for your update. We're glad to know that everything has been sorted. Our corresponding team is instructing the same procedure regarding this problem. Thank you for sharing the resolution here.
2024-1-11
