JustName Posted at 1-13 06:19
I'm using two of Sea Dragon 3000F Auto lights, they are really great and bring a lot of color under water.
Nice shots, did you mount both lights and the camera on a stick ? Can you share a picture of the setup ?
Also, how deep was this ? How does it look without additional lighting, is it still usable with some post-processing to fix white balance (or maybe not needed as I have seen the action 4 had a feature to help with underwater white balance) ?
I can't tell you how deep it was, as I wasn't paying that much attention when I took the photos. Something between 10 and maybe 25 meters. However, visibility was quite poor.
Without the lights, the photos would be significantly worse, and no post-processing would help, everything would remain grey-green. The lights really bring a lot of colour into the picture.
There is a picture with the both lights. The Action 4 is mounted in the middle between the lights.
