Emergency propellor stop?
385 4 1-17 20:57
djiuser_ANs4xZyeMlar
Flight distance : 399272 ft
Hello-
I am wondering if there is any way to kill the Avata propellers in the event of an emergency? Sometimes if the drone needs to be landed quickly to avoid an emergency the landing sequence is either too slow or doesn’t work. Is there any sort of kill switch that can be enabled to halt the propellers in flight?
Thank you.
1-17 20:57
DJI Gamora
Hello, there. Thank you for reaching out. You may perform the Combination Stick Command for emergency landing. You may refer to the image attached below. I hope this information helps.
1-18 00:02
DJI Gamora Posted at 1-18 00:02
[view_image]
This is the two sticks down and in motion? And this works on Avata?
1-18 05:52
GTHero
Flight distance : 1832372 ft
djiuser_ANs4xZyeMlar Posted at 1-18 05:52
Yes, but you have to enable it in your settings under... Settings>Safety>Emergency Propeller Stop
Note that this stick combination also starts the motors.
1-18 14:24
DJI Gamora
Thanks for responding. Yes, this function can be achieved for both the remote controller and DJI RC Motion. However, as mentioned by GTHero, you must enable the Emergency Propeller Stop option to use this function. To learn more, you may visit pages 61-62 of DJI Avata Manuals. I hope this information helps. Thank you for your support.
1-21 03:20
