Stealth...
Had the same issue today. The .txt file on the microsd card show's:
"Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.02.0008.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.07.14 21:42:10 =====================
Result: Abort.
========== 2015.07.14 22:09:38 =====================
Result: Abort.
Result: Abort.
========== 2015.07.16 06:43:15 =====================
Result: Abort.
========== 2015.07.16 17:53:19 =====================
Result: Abort.
========== 2015.07.16 18:16:26 =====================
Result: Abort.
========== 2015.07.18 14:53:18 =====================
Result: Abort.
========== 2015.07.18 21:12:11 =====================
Result: Abort.
========== 2015.07.18 21:20:43 =====================
Result: Abort.
Result: Abort.
========== 2015.07.18 21:43:01 =====================
Result: Abort.
========== 2015.07.20 21:29:24 =====================
Result: Abort.
Result: Abort.
========== 2015.07.21 21:05:30 =====================
Result: Abort.
========== 2015.07.21 21:29:27 =====================
Result: Abort.
========== 2015.07.21 21:30:26 =====================
Result: Abort.
========== 2015.07.23 20:49:02 =====================
Result: Abort.
========== 2015.07.24 20:18:52 =====================
Result: Abort.
========== 2015.07.24 21:04:55 =====================
Result: Abort.
========== 2015.07.24 21:25:42 =====================
Result: Abort.
========== 2015.07.30 18:49:44 =====================
Result: Abort.
========== 2015.07.30 18:58:52 =====================
Result: Abort.
========== 2015.07.30 18:59:59 =====================
Result: Abort.
========== 2015.07.30 21:11:30 =====================
Result: Abort.
========== 2015.07.31 16:54:37 =====================
Result: Abort.
========== 2015.08.02 20:14:53 =====================
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3S_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
========== 2015.08.05 20:00:29 =====================
Upgrading ...
Result: Success.
========== 2015.08.05 20:06:17 =====================
Result: Abort.
========== 2015.08.05 21:00:52 =====================
Result: Abort.
========== 2015.08.05 21:39:05 =====================
Result: Abort.
========== 2015.08.06 21:06:30 =====================
Result: Abort.
========== 2015.08.06 21:30:27 =====================
Result: Abort.
========== 2015.08.09 11:24:13 =====================
Result: Abort.
========== 2015.08.09 11:48:02 =====================
Result: Abort.
========== 2015.08.09 11:49:38 =====================
Result: Abort.
========== 2015.08.09 11:51:23 =====================
Result: Abort.
Packet: P3S_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2015.09.13 17:45:39 =====================
Result: Abort.
========== 2015.09.13 17:56:40 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft."
I checked the .txt file in the hidden directory misc/log with the next results:
" [00011731][01 00] Firmware upgrade finished successfully.
[00011853]Done.
[00011890]Packet [C:\P3S_FW_V01.02.0008.bin] resumed, card sn [0xb0ce57b9].
[00011928]Version checking[2]...
[00012003][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012063][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012107][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012169][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012283][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012358][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012434][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012508][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012598][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012635][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012713][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00012856][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00012909][19 00][00] v1.0.8.96 -> v1.0.8.96
[00012945][01 00][05] v1.14.3090 -> v1.14.3090
[00012980][01 01][00] v1.7.2735 -> v1.14.3090 need upgrade
[00013012]Done.
[00013048]Firmware upgrading[2]...
[00013203][01 01] Firmware upgrade start...
[00043484][01 01] Firmware upgrade finished successfully.
[00043547][17 00] Firmware upgrade start...
[00137096][17 00] Firmware upgrade finished successfully.
[00137146][17 01] Firmware upgrade start...
[00205061][17 01] Firmware upgrade finished successfully.
[00205114][03 05] Firmware upgrade start...
[00278963][03 05] Firmware upgrade finished successfully.
[00279200][03 06] Firmware upgrade start...
[00584951][03 06] Firmware upgrade finished successfully.
[00585016][04 00] Firmware upgrade start...
[00643211][04 00] Firmware upgrade finished successfully.
[00643245]Done.
[00643281]Version checking[3]...
[00643354][03 05][05] v34.2.0.9 -> v34.2.0.9
[00643416][03 06][05] v2.2.6.8 -> v2.2.6.8
[00643461][04 00][05] v1.38.0.0 -> v1.38.0.0
[00643505][09 00][00] v1.7.0.3 -> v1.7.0.3
[00643622][11 00][00] v1.6.1.0 -> v1.6.0.0
[00643690][12 00][00] v1.8.0.0 -> v1.8.0.0
[00643826][12 01][00] v1.8.0.0 -> v1.8.0.0
[00643905][12 02][00] v1.8.0.0 -> v1.8.0.0
[00644084][12 03][00] v1.8.0.0 -> v1.8.0.0
[00644130][15 00][00] v1.1.2.0 -> v1.1.2.0
[00644205][17 00][05] v1.1.1.6 -> v1.1.1.6
[00644325][17 01][05] v1.0.2.5 -> v1.0.2.5
[00644384][19 00][00] v1.0.8.96 -> v1.0.8.96
[00644426][01 00][05] v1.14.3090 -> v1.14.3090
[00644460][01 01][05] v1.14.3090 -> v1.14.3090
[00644493]Packet upgrade finish successfully.
[00011958]========== remo-con disconnect. boot(15) ============
[00011998]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012032]Packet upgrade start...
[00012074]Packet checking...
[00012112]Done.
[00012155]Version checking[1]...
[00012216][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012275][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012337][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012389][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012495][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012595][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012670][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012744][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012835][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012875][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012946][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013050][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013110][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013148][01 00][00] v1.14.3090 -> v1.14.3090
[00013186][01 01][00] v1.14.3090 -> v1.14.3090
[00013221]Packet upgrade cancelled at version checking.
[00011985]========== 2015.07.14 21:42:10. boot(15) ============
[00012023]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012060]Packet upgrade start...
[00012106]Packet checking...
[00012147]Done.
[00012183]Version checking[1]...
[00012259][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012321][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012365][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012423][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012539][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012623][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012713][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012813][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012993][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013036][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013124][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013246][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013304][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013343][01 00][00] v1.14.3090 -> v1.14.3090
[00013387][01 01][00] v1.14.3090 -> v1.14.3090
[00013425]Packet upgrade cancelled at version checking.
[00012022]========== 2015.07.14 22:09:38. boot(15) ============
[00012055]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012091]Packet upgrade start...
[00012131]Packet checking...
[00012172]Done.
[00012208]Version checking[1]...
[00012293][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012376][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012417][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012473][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012596][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012689][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012787][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012866][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012941][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012984][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013060][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013176][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013238][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013272][01 00][00] v1.14.3090 -> v1.14.3090
[00013313][01 01][00] v1.14.3090 -> v1.14.3090
[00013350]Packet upgrade cancelled at version checking.
[00011979]========== remo-con disconnect. boot(15) ============
[00012015]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012048]Packet upgrade start...
[00012087]Packet checking...
[00012128]Done.
[00012165]Version checking[1]...
[00012236][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012294][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012340][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012398][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012516][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012608][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012689][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012789][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012944][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013065][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013180][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013241][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013278][01 00][00] v1.14.3090 -> v1.14.3090
[00013311][01 01][00] v1.14.3090 -> v1.14.3090
[00013346]Packet upgrade cancelled at version checking.
[00011982]========== 2015.07.16 06:43:15. boot(15) ============
[00012018]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012100]Packet checking...
[00012138]Done.
[00012174]Version checking[1]...
[00012249][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012309][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012359][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012418][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012530][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012604][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012690][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012804][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012879][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012919][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012995][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013132][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013185][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013218][01 00][00] v1.14.3090 -> v1.14.3090
[00013255][01 01][00] v1.14.3090 -> v1.14.3090
[00013292]Packet upgrade cancelled at version checking.
[00012008]========== 2015.07.16 17:53:19. boot(15) ============
[00012045]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012082]Packet upgrade start...
[00012119]Packet checking...
[00012163]Done.
[00012199]Version checking[1]...
[00012276][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012361][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012405][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012456][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012581][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012672][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012770][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012871][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013071][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013110][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013201][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013326][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013376][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013411][01 00][00] v1.14.3090 -> v1.14.3090
[00013454][01 01][00] v1.14.3090 -> v1.14.3090
[00013489]Packet upgrade cancelled at version checking.
[00012048]========== 2015.07.16 18:16:26. boot(15) ============
[00012092]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012128]Packet upgrade start...
[00012170]Packet checking...
[00012208]Done.
[00012251]Version checking[1]...
[00012326][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012406][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012450][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012506][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012628][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012722][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012796][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012880][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012960][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013000][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013076][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013200][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013257][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013291][01 00][00] v1.14.3090 -> v1.14.3090
[00013330][01 01][00] v1.14.3090 -> v1.14.3090
[00013372]Packet upgrade cancelled at version checking.
[00012195]========== 2015.07.18 14:53:18. boot(15) ============
[00012233]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012266]Packet upgrade start...
[00012306]Packet checking...
[00012345]Done.
[00012387]Version checking[1]...
[00012472][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012556][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012598][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012652][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012773][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012867][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012947][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013038][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013213][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013258][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013343][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013463][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013513][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013549][01 00][00] v1.14.3090 -> v1.14.3090
[00013586][01 01][00] v1.14.3090 -> v1.14.3090
[00013623]Packet upgrade cancelled at version checking.
[00011994]========== 2015.07.18 21:12:11. boot(15) ============
[00012032]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012071]Packet upgrade start...
[00012116]Packet checking...
[00012157]Done.
[00012195]Version checking[1]...
[00012273][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012335][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012377][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012444][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012559][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012650][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012754][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012830][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012905][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012952][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013025][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013140][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013204][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013241][01 00][00] v1.14.3090 -> v1.14.3090
[00013279][01 01][00] v1.14.3090 -> v1.14.3090
[00013321]Packet upgrade cancelled at version checking.
[00011996]========== 2015.07.18 21:20:43. boot(15) ============
[00012041]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012079]Packet upgrade start...
[00012121]Packet checking...
[00012160]Done.
[00012205]Version checking[1]...
[00012285][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012365][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012407][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012568][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012654][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012745][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012822][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012919][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013192][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013275][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013393][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013446][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013488][01 00][00] v1.14.3090 -> v1.14.3090
[00013526][01 01][00] v1.14.3090 -> v1.14.3090
[00013563]Packet upgrade cancelled at version checking.
[00012094]========== remo-con disconnect. boot(15) ============
[00012137]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012173]Packet upgrade start...
[00012226]Packet checking...
[00012268]Done.
[00012306]Version checking[1]...
[00012405][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012484][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012545][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012604][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012724][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012813][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012914][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013014][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013105][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013152][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013230][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013364][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013425][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013470][01 00][00] v1.14.3090 -> v1.14.3090
[00013511][01 01][00] v1.14.3090 -> v1.14.3090
[00013552]Packet upgrade cancelled at version checking.
[00012590]========== 2015.07.18 21:43:02. boot(15) ============
[00012628]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012668]Packet upgrade start...
[00012709]Packet checking...
[00012749]Done.
[00012787]Version checking[1]...
[00012849][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012910][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012962][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013019][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013130][11 00][00] v1.6.1.0 -> v1.6.0.0
[00013205][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013280][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013375][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013475][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013600][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013677][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013805][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013880][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013917][01 00][00] v1.14.3090 -> v1.14.3090
[00013959][01 01][00] v1.14.3090 -> v1.14.3090
[00013996]Packet upgrade cancelled at version checking.
[00013320]========== 2015.07.20 21:29:26. boot(15) ============
[00013357]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00013403]Packet upgrade start...
[00013445]Packet checking...
[00013485]Done.
[00013522]Version checking[1]...
[00013596][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013677][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013722][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013783][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013917][11 00][00] v1.6.1.0 -> v1.6.0.0
[00014001][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014091][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014166][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014251][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014293][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014361][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014480][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014540][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014580][01 00][00] v1.14.3090 -> v1.14.3090
[00014620][01 01][00] v1.14.3090 -> v1.14.3090
[00014661]Packet upgrade cancelled at version checking.
[00012515]========== remo-con disconnect. boot(15) ============
[00012557]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012598]Packet upgrade start...
[00012643]Packet checking...
[00012691]Done.
[00012734]Version checking[1]...
[00012862][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012937][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012989][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013037][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013163][11 00][00] v1.6.1.0 -> v1.6.0.0
[00013253][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013413][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013513][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013617][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013744][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013847][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013987][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014038][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014080][01 00][00] v1.14.3090 -> v1.14.3090
[00014127][01 01][00] v1.14.3090 -> v1.14.3090
[00014172]Packet upgrade cancelled at version checking.
[00012041]========== 2015.07.21 21:05:30. boot(15) ============
[00012080]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012122]Packet upgrade start...
[00012174]Packet checking...
[00012216]Done.
[00012258]Version checking[1]...
[00012338][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012419][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012472][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012538][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012658][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012753][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012849][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012947][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013028][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013072][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013163][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013283][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013338][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013380][01 00][00] v1.14.3090 -> v1.14.3090
[00013426][01 01][00] v1.14.3090 -> v1.14.3090
[00013465]Packet upgrade cancelled at version checking.
[00012133]========== 2015.07.21 21:29:27. boot(15) ============
[00012172]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012212]Packet upgrade start...
[00012255]Packet checking...
[00012296]Done.
[00012339]Version checking[1]...
[00012426][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012506][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012553][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012606][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012727][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012816][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012916][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013016][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013116][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013248][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013330][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013451][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013505][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013547][01 00][00] v1.14.3090 -> v1.14.3090
[00013588][01 01][00] v1.14.3090 -> v1.14.3090
[00013632]Packet upgrade cancelled at version checking.
[00012190]========== 2015.07.21 21:30:26. boot(15) ============
[00012231]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012273]Packet upgrade start...
[00012316]Packet checking...
[00012359]Done.
[00012403]Version checking[1]...
[00012491][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012555][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012604][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012674][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012793][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012905][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013007][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013109][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013206][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013251][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013337][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013477][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013536][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013577][01 00][00] v1.14.3090 -> v1.14.3090
[00013621][01 01][00] v1.14.3090 -> v1.14.3090
[00013665]Packet upgrade cancelled at version checking.
[00012250]========== 2015.07.23 20:49:02. boot(15) ============
[00012290]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012332]Packet upgrade start...
[00012376]Packet checking...
[00012419]Done.
[00012462]Version checking[1]...
[00012544][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012621][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012670][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012729][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012843][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012915][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013013][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013113][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013211][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013335][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013413][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013530][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013600][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013646][01 00][00] v1.14.3090 -> v1.14.3090
[00013688][01 01][00] v1.14.3090 -> v1.14.3090
[00013732]Packet upgrade cancelled at version checking.
[00012043]========== 2015.07.24 20:18:52. boot(15) ============
[00012087]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012134]Packet upgrade start...
[00012181]Packet checking...
[00012224]Done.
[00012268]Version checking[1]...
[00012336][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012413][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012461][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012523][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012636][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012723][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012827][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012925][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013015][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013059][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013142][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013266][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013329][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013372][01 00][00] v1.14.3090 -> v1.14.3090
[00013414][01 01][00] v1.14.3090 -> v1.14.3090
[00013456]Packet upgrade cancelled at version checking.
[00012157]========== 2015.07.24 21:04:55. boot(15) ============
[00012200]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012246]Packet upgrade start...
[00012292]Packet checking...
[00012335]Done.
[00012380]Version checking[1]...
[00012461][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012541][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012589][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012662][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012786][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012896][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012996][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013096][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013196][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013330][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013411][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013551][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013621][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013666][01 00][00] v1.14.3090 -> v1.14.3090
[00013710][01 01][00] v1.14.3090 -> v1.14.3090
[00013754]Packet upgrade cancelled at version checking.
[00778165]========== 2015.07.24 21:25:42. boot(1) ============
[00778219]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00778263]Packet upgrade start...
[00778312]Packet checking...
[00778362]Done.
[00778409]Version checking[1]...
[00778486][03 05][00] v34.2.0.9 -> v34.2.0.9
[00778573][03 06][00] v2.2.6.8 -> v2.2.6.8
[00778631][04 00][00] v1.38.0.0 -> v1.38.0.0
[00778690][09 00][00] v1.7.0.3 -> v1.7.0.3
[00778825][11 00][00] v1.6.1.0 -> v1.6.0.0
[00778922][12 00][00] v1.8.0.0 -> v1.8.0.0
[00779019][12 01][00] v1.8.0.0 -> v1.8.0.0
[00779120][12 02][00] v1.8.0.0 -> v1.8.0.0
[00779222][12 03][00] v1.8.0.0 -> v1.8.0.0
[00779270][15 00][00] v1.1.2.0 -> v1.1.2.0
[00779353][17 00][00] v1.1.1.6 -> v1.1.1.6
[00779498][17 01][00] v1.0.2.5 -> v1.0.2.5
[00779573][19 00][00] v1.0.8.96 -> v1.0.8.96
[00779617][01 00][00] v1.14.3090 -> v1.14.3090
[00779667][01 01][00] v1.14.3090 -> v1.14.3090
[00779714]Packet upgrade cancelled at version checking.
[00013089]========== 2015.07.30 18:49:45. boot(15) ============
[00013141]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00013188]Packet upgrade start...
[00013239]Packet checking...
[00013287]Done.
[00013334]Version checking[1]...
[00013424][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013518][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013578][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013649][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013760][11 00][00] v1.6.1.0 -> v1.6.0.0
[00013849][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013939][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014039][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014140][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014284][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014365][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014486][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014550][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014597][01 00][00] v1.14.3090 -> v1.14.3090
[00014644][01 01][00] v1.14.3090 -> v1.14.3090
[00014690]Packet upgrade cancelled at version checking.
[00012239]========== 2015.07.30 18:58:52. boot(15) ============
[00012285]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012335]Packet upgrade start...
[00012387]Packet checking...
[00012437]Done.
[00012494]Version checking[1]...
[00012573][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012654][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012706][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012765][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012874][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012965][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013056][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013153][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013256][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013315][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013433][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013575][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013634][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013683][01 00][00] v1.14.3090 -> v1.14.3090
[00013737][01 01][00] v1.14.3090 -> v1.14.3090
[00013784]Packet upgrade cancelled at version checking.
[00012098]========== 2015.07.30 18:59:59. boot(1) ============
[00012143]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012188]Packet upgrade start...
[00012236]Packet checking...
[00012281]Done.
[00012325]Version checking[1]...
[00012418][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012517][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012575][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012632][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012757][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012862][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012972][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013072][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013162][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013291][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013402][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013544][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013612][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013667][01 00][00] v1.14.3090 -> v1.14.3090
[00013713][01 01][00] v1.14.3090 -> v1.14.3090
[00013759]Packet upgrade cancelled at version checking.
[00012199]========== 2015.07.30 21:11:30. boot(15) ============
[00012249]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012299]Packet upgrade start...
[00012353]Packet checking...
[00012403]Done.
[00012457]Version checking[1]...
[00012553][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012627][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012678][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012747][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012877][11 00][00] v1.6.1.0 -> v1.6.0.0
[00012983][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013080][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013182][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013301][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013351][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013435][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013558][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013628][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013677][01 00][00] v1.14.3090 -> v1.14.3090
[00013732][01 01][00] v1.14.3090 -> v1.14.3090
[00013781]Packet upgrade cancelled at version checking.
[00012877]========== 2015.07.31 16:54:38. boot(15) ============
[00012925]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57b9].
[00012972]Packet upgrade start...
[00013021]Packet checking...
[00013076]Done.
[00013125]Version checking[1]...
[00013207][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013286][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013339][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013411][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013547][11 00][00] v1.6.1.0 -> v1.6.0.0
[00013637][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013737][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013837][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013935][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014080][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014171][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014315][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014390][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014438][01 00][00] v1.14.3090 -> v1.14.3090
[00014485][01 01][00] v1.14.3090 -> v1.14.3090
[00014534]Packet upgrade cancelled at version checking.
[00012187]========== 2015.08.02 20:15:00. boot(15) ============
[00012279]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xb0ce57bb].
[00012333]Packet upgrade start...
[00012397]Packet checking...
[00012449]Done.
[00012505]Version checking[1]...
[00012605][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012705][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012776][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012845][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012990][11 00][00] v1.6.1.0 -> v1.6.0.0
[00013100][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013225][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013327][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013440][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013499][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013595][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013736][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013805][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013858][01 00][00] v1.14.3090 -> v1.14.3090
[00013909][01 01][00] v1.14.3090 -> v1.14.3090
[00013964]Packet upgrade cancelled at version checking.
[00014790]========== remo-con disconnect. boot(15) ============
[00014840]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00014890]Packet upgrade start...
[00014943]Packet checking...
[00014996]Done.
[00015048]Version checking[1]...
[00015143][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015224][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00015274][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00015342][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015482][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00015572][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015683][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015772][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015976][12 03][00] v1.8.0.0 -> v1.8.0.0
[00016028][15 00][00] v1.1.2.0 -> v1.1.2.0
[00016132][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00016272][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00016342][19 00][00] v1.0.8.96 -> v1.0.8.96
[00016391][01 00][00] v1.14.3090 -> v1.20.3419 need upgrade
[00016440][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
[00016490]Done.
[00018541]Waiting for user confirm...
[00028588]Timeout, start upgrade automatically.
[00028687]Firmware upgrading[1]...
[00042733][01 00] Firmware upgrade start...
[00011740][01 00] Firmware upgrade finished successfully.
[00011791]Done.
[00011850]Packet [C:\P3S_FW_V01.03.0020.bin] resumed, card sn [0xb0ce57b9].
[00011904]Packet vlink 01.03.0020 <-> 01.01.0009.
[00011988]Version checking[2]...
[00012084][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012180][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012244][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012318][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012462][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00012572][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012672][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012772][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012872][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012924][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013028][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013168][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013285][01 00][05] v1.20.3419 -> v1.20.3419
[00013334][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
[00013384]Done.
[00013435]Firmware upgrading[2]...
[00013607][01 01] Firmware upgrade start...
[00043899][01 01] Firmware upgrade finished successfully.
[00043970][17 00] Firmware upgrade start...
[00133209][17 00] Firmware upgrade finished successfully.
[00133269][17 01] Firmware upgrade start...
[00202318][17 01] Firmware upgrade finished successfully.
[00202376][11 00] Firmware upgrade start...
[00255091][11 00] Firmware upgrade finished successfully.
[00255433][03 06] Firmware upgrade start...
[00577840][03 06] Firmware upgrade finished successfully.
[00577917][04 00] Firmware upgrade start...
[00635671][04 00] Firmware upgrade finished successfully.
[00635722]Done.
[00635784]Version checking[3]...
[00635867][03 05][00] v34.2.0.9 -> v34.2.0.9
[00635944][03 06][05] v2.2.6.19 -> v2.2.6.19
[00636000][04 00][05] v1.40.0.0 -> v1.40.0.0
[00636073][09 00][00] v1.7.0.3 -> v1.7.0.3
[00636185][11 00][05] v1.7.0.0 -> v1.7.0.0
[00636274][12 00][00] v1.8.0.0 -> v1.8.0.0
[00636368][12 01][00] v1.8.0.0 -> v1.8.0.0
[00636468][12 02][00] v1.8.0.0 -> v1.8.0.0
[00636568][12 03][00] v1.8.0.0 -> v1.8.0.0
[00636620][15 00][00] v1.1.2.0 -> v1.1.2.0
[00636714][17 00][05] v1.1.1.7 -> v1.1.1.7
[00636893][17 01][05] v1.0.2.7 -> v1.0.2.7
[00636973][19 00][00] v1.0.8.96 -> v1.0.8.96
[00637025][01 00][05] v1.20.3419 -> v1.20.3419
[00637075][01 01][05] v1.20.3419 -> v1.20.3419
[00637124]Packet upgrade finish successfully.
[00012220]========== 2015.08.05 20:00:29. boot(15) ============
[00012269]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00012316]Packet upgrade start...
[00012369]Packet checking...
[00012423]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012474]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012522]Done.
[00012571]Version checking[1]...
[00012664][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012763][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012818][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012890][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013007][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013119][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013217][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013319][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013420][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013474][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013550][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013709][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013767][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013827][01 00][00] v1.20.3419 -> v1.20.3419
[00013952][01 01][00] v1.20.3419 -> v1.20.3419
[00014003]Done.
[00016053]Waiting for user confirm...
[00026104]Timeout, start upgrade automatically.
[00026203]Firmware upgrading[1]...
[00026266][11 00] Firmware upgrade start...
[00077946][11 00] Firmware upgrade finished successfully.
[00077998]Done.
[00078047]Version checking[2]...
[00078133][03 05][00] v34.2.0.9 -> v34.2.0.9
[00078213][03 06][00] v2.2.6.19 -> v2.2.6.19
[00078275][04 00][00] v1.40.0.0 -> v1.40.0.0
[00078344][09 00][00] v1.7.0.3 -> v1.7.0.3
[00078453][11 00][05] v1.7.0.0 -> v1.7.0.0
[00078548][12 00][00] v1.8.0.0 -> v1.8.0.0
[00078645][12 01][00] v1.8.0.0 -> v1.8.0.0
[00078725][12 02][00] v1.8.0.0 -> v1.8.0.0
[00078821][12 03][00] v1.8.0.0 -> v1.8.0.0
[00078873][15 00][00] v1.1.2.0 -> v1.1.2.0
[00078958][17 00][00] v1.1.1.7 -> v1.1.1.7
[00079096][17 01][00] v1.0.2.7 -> v1.0.2.7
[00079170][19 00][00] v1.0.8.96 -> v1.0.8.96
[00079222][01 00][00] v1.20.3419 -> v1.20.3419
[00079272][01 01][00] v1.20.3419 -> v1.20.3419
[00079323]Packet upgrade finish successfully.
[00012462]========== 2015.08.05 20:06:18. boot(15) ============
[00012515]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00012571]Packet upgrade start...
[00012628]Packet checking...
[00012679]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012731]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012783]Done.
[00012835]Version checking[1]...
[00012928][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013008][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013078][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013148][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013272][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013375][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013476][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013589][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013702][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013758][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013859][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013987][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014182][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014243][01 00][00] v1.20.3419 -> v1.20.3419
[00014298][01 01][00] v1.20.3419 -> v1.20.3419
[00014349]Packet upgrade cancelled at version checking.
[00012185]========== 2015.08.05 21:00:52. boot(15) ============
[00012243]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00012295]Packet upgrade start...
[00012356]Packet checking...
[00012415]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012472]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012529]Done.
[00012586]Version checking[1]...
[00012694][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012814][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012874][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012969][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013109][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013222][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013323][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013444][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013572][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013627][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013743][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013878][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013969][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014027][01 00][00] v1.20.3419 -> v1.20.3419
[00014081][01 01][00] v1.20.3419 -> v1.20.3419
[00014140]Packet upgrade cancelled at version checking.
[00013812]========== 2015.08.05 21:39:07. boot(15) ============
[00013868]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00013922]Packet upgrade start...
[00013985]Packet checking...
[00014040]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014094]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014149]Done.
[00014201]Version checking[1]...
[00014300][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014396][03 06][00] v2.2.6.19 -> v2.2.6.19
[00014456][04 00][00] v1.40.0.0 -> v1.40.0.0
[00014536][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014655][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014767][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014892][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015106][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015209][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015268][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015365][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015505][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015592][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015654][01 00][00] v1.20.3419 -> v1.20.3419
[00015710][01 01][00] v1.20.3419 -> v1.20.3419
[00015775]Packet upgrade cancelled at version checking.
[00013091]========== 2015.08.06 21:06:31. boot(15) ============
[00013144]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00013198]Packet upgrade start...
[00013257]Packet checking...
[00013312]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013368]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013422]Done.
[00013476]Version checking[1]...
[00013573][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013675][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013743][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013819][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013932][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014046][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014148][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014266][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014379][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014437][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014541][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014683][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014768][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014825][01 00][00] v1.20.3419 -> v1.20.3419
[00014877][01 01][00] v1.20.3419 -> v1.20.3419
[00014934]Packet upgrade cancelled at version checking.
[00013368]========== 2015.08.06 21:30:29. boot(15) ============
[00013422]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00013476]Packet upgrade start...
[00013535]Packet checking...
[00013589]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013646]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013705]Done.
[00013763]Version checking[1]...
[00013846][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013945][03 06][00] v2.2.6.19 -> v2.2.6.19
[00014086][04 00][00] v1.40.0.0 -> v1.40.0.0
[00014170][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014305][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014425][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014525][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014634][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014730][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014788][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014890][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015049][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015129][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015184][01 00][00] v1.20.3419 -> v1.20.3419
[00015241][01 01][00] v1.20.3419 -> v1.20.3419
[00015295]Packet upgrade cancelled at version checking.
[00013271]========== 2015.08.09 11:24:15. boot(15) ============
[00013333]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00013393]Packet upgrade start...
[00013459]Packet checking...
[00013523]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013586]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013649]Done.
[00013711]Version checking[1]...
[00013809][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013912][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013987][04 00][00] v1.40.0.0 -> v1.40.0.0
[00014074][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014213][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014364][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014467][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014590][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014697][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014755][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014853][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014994][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015067][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015123][01 00][00] v1.20.3419 -> v1.20.3419
[00015181][01 01][00] v1.20.3419 -> v1.20.3419
[00015236]Packet upgrade cancelled at version checking.
[00012828]========== 2015.08.09 11:48:03. boot(15) ============
[00012882]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00012938]Packet upgrade start...
[00012998]Packet checking...
[00013058]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013204]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013263]Done.
[00013318]Version checking[1]...
[00013417][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013516][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013588][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013662][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013797][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013927][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014027][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014127][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014227][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014285][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014383][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014546][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014622][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014678][01 00][00] v1.20.3419 -> v1.20.3419
[00014735][01 01][00] v1.20.3419 -> v1.20.3419
[00014789]Packet upgrade cancelled at version checking.
[00012208]========== 2015.08.09 11:49:38. boot(15) ============
[00012272]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00012329]Packet upgrade start...
[00012389]Packet checking...
[00012447]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012504]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012561]Done.
[00012618]Version checking[1]...
[00012698][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012818][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012881][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012972][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013118][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013227][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013318][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013427][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013552][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013611][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013708][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013888][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013974][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014030][01 00][00] v1.20.3419 -> v1.20.3419
[00014086][01 01][00] v1.20.3419 -> v1.20.3419
[00014144]Packet upgrade cancelled at version checking.
[00012227]========== 2015.08.09 11:51:23. boot(15) ============
[00012285]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xb0ce57b9].
[00012342]Packet upgrade start...
[00012404]Packet checking...
[00012464]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012521]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012580]Done.
[00012637]Version checking[1]...
[00012736][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012836][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012901][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012982][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013116][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013226][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013326][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013426][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013527][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013587][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013683][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013863][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013941][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013999][01 00][00] v1.20.3419 -> v1.20.3419
[00014057][01 01][00] v1.20.3419 -> v1.20.3419
[00014114]Packet upgrade cancelled at version checking.
[00013758]========== remo-con disconnect. boot(15) ============
[00013817]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0xb0ce57b9].
[00013878]Packet upgrade start...
[00013944]Packet checking...
[00014002]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014065]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014120]Done.
[00014185]Version checking[1]...
[00014269][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014389][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00014455][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00014530][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014669][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014784][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014904][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015015][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015116][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015184][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015400][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015555][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015630][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015692][01 00][00] v1.20.3419 -> v1.21.3647 need upgrade
[00015759][01 01][00] v1.20.3419 -> v1.21.3647 need upgrade
[00015825]Done.
[00017883]Waiting for user confirm...
[00027942]Timeout, start upgrade automatically.
[00028060]Firmware upgrading[1]...
[00042897][01 00] Firmware upgrade start...
[00011747][01 00] Firmware upgrade finished successfully.
[00011826]Done.
[00011881]Packet [C:\P3S_FW_V01.04.0010.bin] resumed, card sn [0xb0ce57b9].
[00011954]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012011]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012071]Version checking[2]...
[00012179][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012278][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00012351][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00012436][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012583][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012691][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012826][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00012926][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013051][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013117][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013223][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013360][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013436][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013498][01 00][05] v1.21.3647 -> v1.21.3647
[00013560][01 01][00] v1.20.3419 -> v1.21.3647 need upgrade
[00013621]Done.
[00013678]Firmware upgrading[2]...
[00013863][01 01] Firmware upgrade start...
[00044160][01 01] Firmware upgrade finished successfully.
[00044238][12 00] Firmware upgrade start...
[00110911][12 00] Firmware upgrade finished successfully.
[00110995][12 01] Firmware upgrade start...
[00183098][12 01] Firmware upgrade finished successfully.
[00183181][12 02] Firmware upgrade start...
[00253359][12 02] Firmware upgrade finished successfully.
[00253522][12 03] Firmware upgrade start...
[00316909][12 03] Firmware upgrade finished successfully.
[00317178][03 06] Firmware upgrade start...
[00646268][03 06] Firmware upgrade finished successfully.
[00646361][04 00] Firmware upgrade start...
[00706236][04 00] Firmware upgrade finished successfully.
[00706298]Done.
[00706363]Version checking[3]...
[00706447][03 05][00] v34.2.0.9 -> v34.2.0.9
[00706548][03 06][05] v2.3.0.13 -> v2.3.0.13
[00706607][04 00][05] v1.41.0.0 -> v1.41.0.0
[00706698][09 00][00] v1.7.0.3 -> v1.7.0.3
[00706872][11 00][00] v1.7.0.0 -> v1.7.0.0
[00706983][12 00][05] v1.10.0.0 -> v1.10.0.0
[00707081][12 01][05] v1.10.0.0 -> v1.10.0.0
[00707197][12 02][05] v1.10.0.0 -> v1.10.0.0
[00707307][12 03][05] v1.10.0.0 -> v1.10.0.0
[00707365][15 00][00] v1.1.2.0 -> v1.1.2.0
[00707463][17 00][00] v1.1.1.7 -> v1.1.1.7
[00707596][17 01][00] v1.0.2.7 -> v1.0.2.7
[00707676][19 00][00] v1.0.8.96 -> v1.0.8.96
[00707741][01 00][05] v1.21.3647 -> v1.21.3647
[00707803][01 01][05] v1.21.3647 -> v1.21.3647
[00707866]Packet upgrade finish successfully.
[00012262]========== remo-con disconnect. boot(15) ============
[00012325]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0xb0ce57b9].
[00012384]Packet upgrade start...
[00012455]Packet checking...
[00012516]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012580]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012642]Done.
[00012697]Version checking[1]...
[00012824][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012929][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012995][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013078][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013224][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013337][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013462][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013583][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013698][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013764][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013854][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013999][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014178][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014241][01 00][00] v1.21.3647 -> v1.21.3647
[00014298][01 01][00] v1.21.3647 -> v1.21.3647
[00014367]Packet upgrade cancelled at version checking.
[00012293]========== 2015.09.13 17:45:40. boot(15) ============
[00012358]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0xb0ce57b9].
[00012417]Packet upgrade start...
[00012490]Packet checking...
[00012554]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012620]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012683]Done.
[00012739]Version checking[1]...
[00012828][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012934][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013002][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013080][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013210][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013320][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013444][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013562][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013666][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013737][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013836][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013983][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014079][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014140][01 00][00] v1.21.3647 -> v1.21.3647
[00014208][01 01][00] v1.21.3647 -> v1.21.3647
[00014267]Packet upgrade cancelled at version checking.
[00012257]========== 2015.09.13 17:56:41. boot(15) ============
[00012320]Packet [C:\P3S_FW_V01.04.0010.bin] detected, card sn [0xb0ce57b9].
[00012454]Packet checking...
[00012517]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012578]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012642]Done.
[00012704]Version checking[1]...
[00012816][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012919][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013069][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013219][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013326][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013531][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013656][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013780][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013847][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013945][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014085][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014167][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014237][01 00][00] v1.21.3647 -> v1.21.3647
[00014304][01 01][00] v1.21.3647 -> v1.21.3647
[00014370]Packet upgrade cancelled at version checking"
Now I'm a little confused if this update succeeded or not. Anyone? |
