Air 2s video recording wavy sometimes
2231 16 2024-1-23
Tonyvdb
Flight distance : 9852585 ft
Good day everyone, My Air 2s recently has been doing something strange. I get waves or ripples moving through the video. It is intermitant and only happends off and on.
It started in October of last year and now when it does it it is very noticable. Ive flown in weather conditions like this for several years and never had this issue before. any thoughts as to what is happening?
2024-1-23
DJI Tony
Hi there. Sorry about the trouble. If ever the drone crashes or experiences any collisions, we recommend sending the drone for diagnosis. If not, can you please follow the steps below? (feel free to skip some steps if was already done):
1. Make sure to remove the gimbal protector before powering on the aircraft to prevent the gimbal motor from being stuck, or the gimbal will become shaky.
2. Please check whether the aircraft is in Sports mode (S-mode) when the gimbal becomes shaky. In S-mode, greater emphasis is placed on flight performance. During flight, when the aircraft attitude is too large, the gimbal attitude stabilization cannot be guaranteed. If the gimbal is shaky in S-mode only, which is normal, please switch the flight mode of the aircraft to Normal mode (N-mode) or Cine mode (C-mode) to achieve a more stable view.
3. Please check whether the wind was strong in the flight environment. If the wind is too strong, the aircraft will vibrate, resulting in the image transmission screen being shaky. We recommend that you test the gimbal in a windless or breezy environment.
4. Please perform gimbal calibration in the app. Using with DJI Fly: [Settings -> Control -> Gimbal Calibration].
Have a nice day.
2024-1-23
DowntownRDB
Flight distance : ****
I had that same type of issue recently and I put in a new SD Card and the issue was resolved.  I hope you get it solved as that can be very frustrating.
2024-1-24
Tonyvdb
DowntownRDB Posted at 1-24 04:32
Ok, I have purchased 2 new Sandisc Extreme Pro cards and will try this weekend.
2024-1-24
Tonyvdb
DJI Tony Posted at 1-23 19:17
I have already done all of the above, I will replace the memory card and see if that helps although i have heard that this is a common problem in the colder weather and putting an ND filter on usually fixes the issue so I will try that also
2024-1-24
DowntownRDB
Tonyvdb Posted at 1-24 18:07
I hope it resolves your issue.  All I know is it certainly fixed my similar issue.
2024-1-25
DJI Tony
Tonyvdb Posted at 1-24 18:08
I see. I hope replacing the  MicroSD solves the problem. Please keep us posted. Have a great day.
2024-1-27
Shawgod
Flight distance : 5173104 ft
I had this problem one day while shooting and the problem happened I found because of winds aloft.  When flying my drone at certain altitudes I found that the wind speeds changed direction and speeds.  The speed and direction can be different then what it is on the ground, and in my case it was.  As soon as I got it down to the ground level the swaying went away.  The winds aloft were 35 mph at 300 ft and coming from the north while on the ground it was coming from the south at 10 mph.
2024-1-27
Tonyvdb
Shawgod Posted at 1-27 11:21
There were no winds, I do find that in the really cold weather the props spinning create a false wind reading
2024-1-29
Tonyvdb
So after replacing the card with a new extreme pro card it did seem to be better as i filmed in near freezing temperatures again. I did see a couple spots in the video where it did jitter a bit but it was much less than before. I will keep you updated as i continue testing over the next few weeks.
2024-1-29
Shawgod
Tonyvdb Posted at 1-29 19:56
I am saying there may not of been winds at ground level, but when you were flying the drone could have run into winds at the altitude it was.  It would be hard to tell if it had run into them, but it is possible.
2024-1-31
Tonyvdb
Shawgod Posted at 1-31 06:14
I can assure you the waves in the video is not caused by wind. Its related to temperature and camera its self not being able to cope, the cold seems to reduce the camera ability to process the image when its bright out and snow on the ground . Lots of posts about this issue all over the place. I have found using an ND filter helps.
2024-2-2
Tonyvdb
Ok, need to post another video because I am still seeing the same wavy video  issues.  It comes and goes. I have replaced the SD card (fastest sandisc you can get) and recorded in 4k/60 which is different than I usually do at 2.7k/60
Hopefully someone can tell me what is going on here, This was filmed a week ago and the temperature was -3c and NO wind in the sunshine.
2024-3-16
SiciSnina
Slovakia
Hi i had the same problem. I replaced propellers, SD card, do gimbal calibration but still the same problem. How can i fix it ? I had it 2years i flight it maybe 40times for few minutes...
2024-6-3
Tonyvdb
SiciSnina Posted at 6-3 02:56
If its the same issue as me the gimbal needs to be replaced. Mine is getting worse and worse
2024-7-8
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
We apologize for the inconvenience. Could you please confirm if you have followed the steps provided by DJI Tony in reply #2? Let us know if the issue persists.
Please keep us posted. Thanks!
2024-7-11
DJI Diana
Tonyvdb Posted at 7-8 12:42
Hi there,
We apologize for the inconvenience. Could you please confirm if the issue still persists? If it does, and you have already followed the steps mentioned above, we recommend submitting an Online Repair Request and sending the aircraft back for further diagnosis through this link: (https://www.dji.com/ca/support/repair). Our support team will provide further assistance for you.
If you have any further questions, please feel free to message us for assistance. Thank you.
2024-7-11
