LFLots
Flight distance : 10434964 ft
Brazil
Johnnokomis Posted at 1-25 04:25
Yes this was with a Mavic 3 Pro and an M3E. If the drone isn't perfectly level when you start the motors they'll sometimes go to full speed instantly and require you to stop them and restart. Which can sometimes be tricky on a rocking boat. I've never seen the message that you're describing though. It could have been added with a recent firmware update.
Thank you for following on this. It is very helpful.
Yesterday I did some new test that can be easily replicated if you could.
Test #1: I put the Mavic3Pro on a base tilted about 20 degrees. It had no problem to take off smoothly, so I don't think it has to be perfectly level.
Test #2: I held the Mavic3Pro in my hand and sarted moving it smoothly up and down and tilting it left and right (about 20 degrees to each side) for a few seconds, to simulate a boat standing on the sea (I understand this is not perfect, but very indicative). I got no error messages and was able to take off normally while doing this. So although this kind of movement is bad and sometimes can cause IMU error, specially during startup calibration, that is another issue and a different message.
Test #3: I held the Mavic3Pro as steady as possible, walked at a high pace for 5-10 meters, then status bar turned RED with the message "Aircraft Moviment Detected" and I could not start the motors. This is the issue I am getting on moving boats.
I repeated the test #3 with my Air2S and to my surprise it also blocks the take off now. Since I have previously operated this on ships, I believe this was quietly implemented on a firmware update.
Test #4: I turned on the Mavic3Pro while walking at a fast pace, and started the motors as soon as it allowed, before it was able to detect the movement, and on this case I experienced what you mentioned as the motors were instantly to full speed. I held it and disabled the motors, not sure how it would have taken off.
Test #5: I covered front part of the top of the Mavic3Pro with my hand, blocking the GPS, then walked at a high pace for 5-10 meters... it worked! No error message, since it did not know its position and horizontal speed, just orange status bar saying "take off without gps", which is exactely what you want when taking off from boats (basically the ATTI mode of the Inspire2 and older models). This is probably the SOLUTION because when you take your hand off (to clear the props) it takes a few seconts to re-lock the satelites, and in this meantime you can take off. I just didn't because it was very cumbersome to do this alone, but my colleage will come when it stops raining so we can test this on land and then on the boat.
