DJI Paladin
Hello, jbvid. Thank you for reaching out and we do apologize for the trouble. Please try the solution below:
1. Place pieces of paper on the cold shoe mount of the cage to make the entire cold shoe mount thinner and then install the DJI Mic Series.
2. If there are excessive 1/4'' screw holes on the cage, purchase a 1/4'' screw to cold shoe accessory with one of the features below:
1) There is a certain raised structure on both sides inside the cold shoe mount
2) There is an anti-dropping/restraint design on the side of the cold shoe mount opening
Note
There is a 0~0.3 mm dimensional tolerance in cold shoe mounts on the market. The DJI Mic hot shoe adapter is designed to better fit the camera’s hot shoe mount. |
