P.K.N.E.C
Flight distance : 7566 ft
DJI Paladin Posted at 2-1 01:08
Hi there. Thank you for reaching out. It is recommended to store the batteries in the charging hub. The charging hub automatically checks the battery power every seven days. If you don't have the Battery Charging Hub, we recommend storing the intelligent flight battery in a cool, dry place away from direct sunlight to ensure the built-in LiPo battery does NOT overheat. The recommended storage temperature is between 22° and 28° C. Please note that the discharging function is an Intelligent Flight Battery feature and not in the charging hub. You may try to plug in the said battery on the unit and run the DJI Fly app to check the battery percentage after discharging. Hope this helps.
Thanks for your reply.
I do have the charging hub and the batteries are stored in there.
I have just done a refresh of the updates on both the Air 3 ,TX and 3 batteries this time on my pc using DJI assistant consumer edition.
Which did recognise I needed to update some firmware. which I had previously done over WIFI.
Also you mention LiPo batteries but mine are Li-Ion, just a different chemistry I know but LI-ion is a safer chemistry to work with, I have many experiences with LiPo over the years and following the rules of charge, discharge and storage is very important.
cheers Paul |
