DJI MIC2 Earpods TRRS Ok To Plug Into RX TRS?
331 4 1-31 07:22
manz187
Flight distance : 15866 ft
Hi, I know zero when it comes to audio.
Can I plug in Apple Earpods 3.5mm TRRS into the monitoring TRS jack on the RX?
1-31 07:22
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. You need to have a 3.5mm TRS headphone and plug it into to Monitor Port to monitor the transmitter audio quality. You may refer to the image below. Hope this helps.
2-1 00:23
manz187
So that port is incompatible with TRRS headphones?
2-1 02:58
WebParrot
Flight distance : 23625 ft
manz187 Posted at 2-1 02:58
No... it's a T'RR'S port.There are 'converter' adapters that may work, but those can get clumsy.
2-1 13:09
manz187
WebParrot Posted at 2-1 13:09
Thanks web
2-1 13:12
