DJI Gamora
Hello, there. Thank you for your suggestion. Rest assured that we'll pass it on to the corresponding team for future reference. In the meantime, you may follow our suggestions to prevent the device from automatically powering off.
① Please keep Osmo Action 4 connected to the DJI Mimo App. During this process, you need to avoid disconnection caused by turning off the screen of the phone or running the app in the background. If disconnection occurs, please reconnect in time.
② Enabled the Pre-Rec function. (Notes: When Pre-Rec mode is enabled, the user can only adjust the screen-off time and end prerecording on the camera touchscreen, while other interactions with the touchscreen are not allowed.)
③ It is recommended to use loop recording. When you need to record a normal video, just switch to the desired video mode to shoot. (It needs to start recording, the reason why loop recording is recommended is to avoid recording video taking too long and occupying too much storage.)If using loop recording, it is recommended to add an external device to charge the Osmo Action 4 to avoid the device shutting down due to insufficient power during use.
I hope the information helps. Thank you for your support. |
