sunete
Flight distance : 3592428 ft
Romania
DJI Gamora Posted at 2-23 03:11
Hi, sunete. Thank you for reaching out. DJI Avata features a single-axis gimbal. If the camera view becomes tilted when the aircraft is hovering in Normal mode, this indicates that the aircraft body is tilted. Please try the following operations:
1. Make sure that there is no strong wind in the flight environment.
2. Make sure that the GPS signal is strong in the flight environment.
Hi again ,
I've made the calibrations but i could not test if the issue is gone as at the moment I can only fly indoor, and I cannot test the Manual Mode.. But as I was looking at a wall and I discovered another issue, and after looking again at the video on the SD card of the Avata, another issue has revealed..
So, when I was flying indoor right now, and i was looking at a wall, i saw a black circle like a burnin in the goggles. I looked at the camera and is clean and has no scratches. Afetr that i was looking in the footage on the sd card to see if the burn is visible also, and yes, even when i had the issue from the topic, the burnin like circle is visible especialy when the camera is pointed on light surfaces. and another thing pop in when looking at the footage: there are some artefacts that are present in the goggles and on the SD also.
The Avata is like new, it has no more than 7 flights maximum, without crashes or anything. I also have Care Refresh active on it, but i don't want to pay for a replace unit, as this is for sure a manufacturing issue.
Please advise asap.
Thanks,
Alin |
