Mini 4 pro. error code 180059 vision system
6564 25 2-22 17:48
David Wang33
Hi,
I recently purchased a new mini 4 pro. i am having the error code 180059. all vision system does not work,
I know the aircraft has to be in the air for it to work. I did the refresh of the firmware with dji assistant 2 (consumer drones series) with the aircraft and the RC, but still no luck at all.
It was working fine before, and all of a sudden it has stop working.
I never crashed the aircraft or whatsoever .
Thanks in advance..
2-22 17:48
DJI Gamora
Hi, David Wang33. Thank you for reaching out. Just to confirm, does the aircraft still take off when the error occurs?
2-22 19:07
xLuckyChain
Yes everything work perfectly fine. No issue taking off nor landing.
2-22 19:15
DJI Wanda
xLuckyChain Posted at 2-22 19:15
Hi there, thanks for your reply. The error code 180059 appears when the drone takes off failed, the vision systems failed to detect obstacles. We recommend that you test again to see if it works well when normally taking off.
2-22 22:16
djiuser_7BkkZ6jSB7Ap
Costa Rica
Hello guys , I have the same problem , I can fly the drone but spinet work this  feature .
Any suggestion ?
3-19 13:30
djiuser_0RQHg9U3kdrI
Flight distance : 35246 ft
Brazil
DJI Gamora Posted at 2-22 19:07
Boa noite, tenho um Mini 4 Pro, Atualizei ele recentemente e na primeira tentativa de vôo pós atualização, não consigo se quer ligar os motores do drone, muito menos decolar, aparece o código 180059, Alguém pode me ajudar por favor!
4-24 14:16
DJI Gamora
djiuser_0RQHg9U3kdrI Posted at 4-24 14:16
Hi, djiuser_0RQHg9U3kdrI. Thank you for reaching out. The aircraft will disable vision sensors when it is on the ground to reduce power consumption. When the aircraft takes off, all vision sensors will be enabled and the error will be removed. Please feel free to use them. If you were not able to start the drone, can you please provide a video showing the operation for us to check? Please keep us posted.
4-26 06:06
Cindyc
I have a code 180059 it was working fine for the first few flights. Now I am stuck on this? What do I have to do to resolve this issue?
4-30 10:30
fansa92fbd59
Thailand
DJI Wanda Posted at 2-22 22:16
not true my very new drone runs into a tree!!!
7-3 21:31
DJI Natalia
fansa92fbd59 Posted at 7-3 21:31
Hi there, thank you reaching out and we're sorry to hear what happened to your Could you please verify if there are any visible external damages to your drone? If so, we kindly request you to submit a repair request to initiate the process of sending the product back to us for further diagnosis.at [https://www.dji.com/sg/support/repair]. The corresponding team will inspect the device and update accordingly.
Thank you for your understanding and support!
7-4 03:28
djiuser_YQRNBPho2F5L
Flight distance : 60207 ft
Argentina
hi. got the same issue with the error code 180059 vision system. the drone was working fine. after the update , the issue with this error started..drone never crashed or hit.  tried everuthing but still the error continues. Any solution for this?
7-14 13:51
DJI Diana
Flight distance : 2408 ft
djiuser_YQRNBPho2F5L Posted at 7-14 13:51
Hi there,
thank you for reaching out.
To confirm, the aircraft will disable vision sensors when it is on the ground to reduce power consumption. When the aircraft takes off, all vision sensors will be enabled. Also, can you please provide a screenshot or video of the error while in flight?
Looking forward to your response. Thank you.
7-14 19:43
Argentina
DJI Diana Posted at 7-14 19:43
Hi there,
After flying the drone a few times, the error disappeared, which was not the case yesterday, so the problem has been solved. Thanks for the quick response
7-15 11:27
DJI Natalia
djiuser_YQRNBPho2F5L Posted at 7-15 11:27
Hi there.
We do apologize for the trouble that this has caused. Thank you for keeping us posted. We're glad to hear this has been addressed.
Feel free to contact us if you have other inquiries. Have a nice day ahead!
7-15 22:56
toddsull1969
Same here. I did the update and error code 180059. The drone will not fly. I've reloaded the updates twice, unbound and rebound the controller/drone, and did every step that was in the updates and online. No joy. It's bricked. Flown the mini 4 6 times for $1,400 with all the gear. Super upset...
8-6 08:53
fans213d928d
Same here. Brand new drone and RC. Short test flight, all worked fine. Installed the firmware updates for RC and Mini 4 Pro - "Fluggerät fliegt nicht. Sichtsysteme und Hindernisvermeidung deaktiviert (Code: 180059)". Reset everything multiple times, restartet system - no change. Letting the drone sit for a while does not help as it shuts down relatively quickly to avoid overheating. Very frustrating!
8-11 02:06
DJI Diana
fans213d928d Posted at 8-11 02:06
Hi there,
We apologize for the inconvenience. Could you provide details about the firmware version that was recently updated? Additionally, was the aircraft stationary on the ground when the error occurred? And did any errors arise during flight?
8-13 02:02
DJI Diana
toddsull1969 Posted at 8-6 08:53
Hi there,
The aircraft will disable vision sensors when it is on the ground to reduce power consumption. When the aircraft takes off, all vision sensors will be enabled. Please feel free to use them. May we confirm if the error arises on the ground?
Please keep us posted. Thank you.
8-13 02:05
TONIA147
Do you have problems accessing or login into your social media accounts? If you're experiencing issues with your social media accounts, I advise contacting Angelina. I can tell you that she is very dependable and always willing to assist because she works for META. I suggest contacting her via her Instagram account; Angelina_Christopher1738, or by email at AngelinaChristopher1738@gmail.com. She is your best bet. Rather than feeling upset, her trustworthy and prompt support made me feel comforted. Kindly contact her as soon as possible if you require assistance!
8-13 20:03
djiuser_7LvaKwY3fBt1
hi there. I had the same issue with my drone recently. I installed propeller guards a few times, once you install the guards the omnidirectional sensors stop working automatically. However after you remove the guards the sensor should come back online, mine didnts. It kept telling me the propeller guards are installed and the sensors stopped working. So i "Re-Linked" my drone with the remote control and it solved the problem.
9-1 21:27
Leonardo Alonso
Colombia
En mi caso el drone no deja volar por el error 180059
9-4 10:55
DJI Gamora
Leonardo Alonso Posted at 9-4 10:55
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing.
180059 referring to takeoff failed. The vision systems failed to detect obstacles. Are you also using a DJI Mini 4 Pro? If yes, please take note that DJI Mini 4 Pro doesn't support Vision Calibration on DJI Assistant 2. Vision system cameras may need to be calibrated after being stored for an extended period. A prompt will appear in DJI Fly and calibration will be performed automatically. During regular flight processes, the vision system of the aircraft is automatically calibrated. Make sure your are running on the latest firmware update and please refresh your DA2.
If issue still persist please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering. We are looking forward to your response for further assistance. Thank You
9-5 01:15
djiuser_dG3bug94JWS0
Poland
Hi! I bought a drone on Amazon, today I unpacked it and passed the check to get dji care refresh (the drone was returned) but after starting it up I got two errors, please help PS.the drone in the panel shows that it was activated 48 days ago
9-25 03:05
DJI Natalia
djiuser_dG3bug94JWS0 Posted at 9-25 03:05
Hi! I bought a drone on Amazon, today I unpacked it and passed the check to get dji care refresh (the drone was returned) but after starting it up I got two errors, please help PS.the drone in the panel shows that it was activated 48 days ago[view_image]
Hi there, thank you for reaching out. May I confirm the exact aircraft model and the remote controller you're using? Also, kindly format the microSD card by following the app on-screen instructions or format through a computer and set the file system to exFAT. Please note to save important materials from the microSD card to the computer.
Looking forward to your response. Thank you for your understanding.
9-25 03:33
Poland
DJI Natalia Posted at 9-25 03:33
I have a dji mini 4 pro with a dji rc n2 controller
9-25 04:07
DJI Natalia
djiuser_dG3bug94JWS0 Posted at 9-25 04:07
Hi there, thank you for sharing this details. May I confirm if you've tried formatting the SD card and check if it helps?
9-25 19:33
