DJI Wanda
Hi there, sorry to reply in English. Please try as follows and see if it works, thank you.
1. Check whether the protective cover of the gimbal is removed, and check whether there is any foreign object on the gimbal that causes the gimbal to be stuck. If there is, please remove it;
2. Please use the DA2 software to refresh the latest version of the aircraft and goggles firmware, and then calibrate the IMU and gimbal. |
