Leorex
Flight distance : 225335 ft
South Africa
Hi, can Anyone help me with the following?
1. I'm in South Africa does the Signal Transmission Module for DJI Air 3 Drone 4G Data Module work here?
2. Is it possible to power or connect something like an Rtk module to this port (air 3 module port on the drone)?
3. How True is the following Description of this product?
1. Allows for DJI devices to connect to 4G networks to realize multiple functions such as networking, enhanced image transmission, and network RTK.
2. Realize the integrated installation of the module and for DJI Air 3 aircraft. You can insert the enhanced video transmission module directly into the body of for DJI Air 3 without additional installation kits to efficiently access the 4G network
3. Supports ASDIV (Transmitting Antenna Selection), with better performance and better handling of complex flight scenarios. An eSIM is included so it can be used without an additional card, and physical nano-SIM cards are also supported
4. The enhanced image transmission module can connect your for DJI equipment to the 4G network, provide you with high-speed and stable networking services, and realize enhanced image transmission, network RTK and other functions
5. On the basis of the original image transmission, it cooperates with the 4G network. If the original image transmission signal is blocked or interfered, the user can still control the drone with the help of the 4G network, reducing the chance of disconnection and effectively improving flight safety.
6. Compatible products: suitable for DJI Air 3
