Mic feedback when powered on Lumix s5iix
257 8 3-2 21:34
bitnerbuilt
I have been using the dji mics for a while, they are great. Today i purchased a lumix s5iix. when i plug in the reciever to the camera with the mic cable - no problem. if i then aditionally plug in a usb c cable to the reciever to anything else loud static feedback. If i use the usbc attachment to the camera or anything else, loud feedback static. Works fine if i keep it just on battery power. If i do this when connected to an iphone, no static. (so port is prob fine, its something with the lumix, i also tried several other cables)  I would like to keep it charged however any know issues you could point me to? perhapse an incorrect setting?
Thanks in advance!
3-2 21:34
Hi there, may I confirm if you mean plugging a UBC C cable into the receiver when recording? Could you please provide us with a picture to check your setup?
3-3 04:34
bitnerbuilt
DJI Mindy Posted at 3-3 04:34
sure! Thanks for the quick response. I have attached photos of the basic setup. I figured out this morning that the feedback is only created when plugging via usb or usb-c to usb into my small rig v mount battery. If I plug in the receiver to a usb wall plug it doesn't occur. I would like to plug into the large battery though as it powers the entire mobile rig when I am at trade shows.
3-3 08:55
bitnerbuilt
Any thoughts on a solution?
3-5 21:59
bitnerbuilt Posted at 3-5 21:59
Hi there, thanks for the picture, could you please provide us with the following information?
1. Abnormal footage;
2. Does the feedback static appear continuously or disappear after a while?
3. Will it appear when the RX has no power or will it also appear when it is fully charged?
3-6 02:39
bitnerbuilt
DJI Mindy Posted at 3-6 02:39
1. I have attached a video documenting abnormal footage and a visual on hookup
2. continuous
I have further investigated and found the noise is only present when. DJI mic or Mic2 (I bought the 2 to test) is plugged into the small rig mount battery 99 via usbc or usb
AND
the camera, Panasonic LUMIX s5iix is plugged into the same small right 99 amount battery via the tap plug.
3-6 21:57
bitnerbuilt
here is the video footage
https://youtu.be/JB2i5dXzEaM
3-6 21:58
bitnerbuilt Posted at 3-6 21:58
Thanks for the detailed information. We will forward it to our engineer for further checking again.
3-7 02:13
Thanks for your patience. We heard back from our engineers saying we are testing this issue and will try to fix it. If there is any update, we will keep you in the loop. Thanks for your understanding.
The following is a temporary suggestion for you:
It is recommended that you do not charge the RX while using it for the time being. The battery life of the RX itself is about 6 hours, and you can charge it during your break for next recording.
3-8 00:33
