remote controller cannot read microSD card inside the drone - pls...
219 10 3-6 09:32
SwatiNG
Hi All,
I have a Samsung 64 GB EVO Plus - speed 3 micro SD card. (About 6 of them, hence want these to work)
I can read, and format(ExFAT) each of them on my Macbook.
However, when I insert it inside my drone's microSD card slot, my drone does not detect it.
It stores data in its internal storage.
If I open the remote controller to format the SD card from drone settings - I see SD card selection is disabled as it cannot understand/read that the card is actually inside the drone. Please advise. Attaching pictures.
3-6 09:32
SwatiNG
it gives an option to format  drone internal storage
3-6 09:33
Hi there, may I ask what's the model of your drone? Have you tested with another SD card to see if it works?
3-7 00:26
SwatiNG
Dji Air 2S
3-7 06:22
SwatiNG
No I did not try any other card. As I had 6 of this brand and configuration, want they work. As there are also listed in DJI accepted list of cards.
3-7 06:22
SwatiNG Posted at 3-7 06:22
Could you please test a SD card in the recommended SD card list below to see if it works? https://www.dji.com/air-2s/specs
3-8 03:25
SwatiNG
Same issue with SanDisk Extreme Pro 64GB V30 A2 microSDXC
Why is controller or drone not able to detect or read the card inserted inside the drone
3-9 21:46
DJI Natalia
SwatiNG Posted at 3-9 21:46
I apologize for any inconvenience caused by your usage. You can try using a card reader to confirm if your storage card is functioning properly. If it still cannot be read even after confirming that the storage card is working fine, I suggest you send it back to us for a comprehensive inspection. Please visit https://www.dji.com/support?site=brandsite&from=nav
Thank you
3-10 01:57
SwatiNG
Will do. Thanks
3-11 06:01
SwatiNG
Hi All,
I got it working,
I was inserting the micro SD card and then closing the flap. My remote controller could not detect the card.
Then I saw the video https://www.youtube.com/watch?v=HNoOixU0yVg
That is, after inserting the SD card. We need to manually push the card into the slot. just closing the flap is not enough.
In fact, this time I even left the flap open, and yet my card was very well detected, and read by the controller.
So note - after inserting the micro SD card into the slot, manually push it all the way!!!
Thank you for all the responses.
3-11 22:07
DJI Susan
SwatiNG Posted at 3-11 22:07
Hi All,
I got it working,
Hi, there. We are glad your problem has been resolved. If you have any further questions or concerns, please do not hesitate to contact our support team.
3-11 23:13
