tyler
I have a Phantom 2 with a gopro mounted to a zenmuse H3 3D with the LK24BT, using the iPad groud station. I have been trying to troubleshoot a waypoint problem - on 2 out of the 4 waypoints, on two diffferent paths (and two different areas), the bird won't point at the heading I've indicated for it to hover. HOWEVER
Since I've been running and re-running these in simulation mode hoping it's a user error, the simulator will crash the bird while it is turning - not all of the time. A few times, it has actually overturned the bird in simulation mode and slammed it into the ground. Other times, again while turning, it will drop 50' in the air (which if happened in reality would slam into trees). It seems to go all out nuts when it is trying to stop and turn.
I'm now afraid to fly the drone. Does the iPad really simulate these things - as in is it testing all of the components of the drone? Is this indicating some sort of a problem?
I have re-updated all of the firmware. Other than this constant problem of the drone not pointing in the right direction at some wayppoints, I haven't seen any real problems. The drone has crashed before but I have flown it many times since repairing.
Is the simulator diagnosing something or just a fluke in the software? How can I diagnose this as a problem, if there is one?
Thank you,
Tyler
