Seeking guidance regarding my eligibility for either the "Flyaway Warranty" or "Repair Service."
I've been flying and filming various nature and architectural scenes. During these flights, my drone maintained minimal altitude of approximately 6-7 meters above water or some trees. The first flight proceeded smoothly, but I encountered a connectivity issue when the drone was about 100 meters away from the remote control. Despite setting the home point and the drone successfully returning to it, it took less than 5 seconds for the signal to reconnect. This incident served as a warning, albeit not a significant one. Subsequently, I landed the drone, replaced the battery, and restarted both the controller and the aircraft. No errors were detected, so I initiated the second flight. Unfortunately, this flight proved to be the last. The drone took off normally, and I directed it towards the intended location. However, approximately 40 meters away from the controller and the shoreline(4-5 sec flight time) the drone began to descend rapidly (from approximately 6-7 meters to water level). Despite my attempts to regain control through the controller, the aircraft remained unresponsive and eventually collided with the water. Efforts to retrieve the drone were futile as the water at the crash site is approximately 70 meters deep, leaving me unable to locate the drone.
I have DJI Care Express coverage, but I'm unsure if this situation falls within its scope, or if it would be covered by the standard warranty. (It's worth noting that obstacle avoidance was enabled, and I was filming in Normal mode.) I've included links for both flights. Any assistance would be greatly appreciated. First flight - Link to Airdata report for the first flight - https://app.airdata.com/share/tdNcrz Second flight (Crash) - https://app.airdata.com/share/TosUyn
