Labroides
Flight distance : 9991457 ft
You can see a summary of your flight data here.
https://www.phantomhelp.com/logviewer/4BPDBTJ6AB4AAJ3XV8SO/
You descended far down a high cliff, staying close to the cliff.
As you went beyond -11 metres, the number of satellites began to fall, because the cliff wall was blocking much of the sky and the sats in that part of the sky.
As you reached -24 metres, you lost full GPS, because you had lost too many sats.
Without GPS, the drone is controllable, but it has lost the ability to hold horizontal position.
You continued to descend and as you reached -280 metres the drone collided with an obstacle and started tumbling.
Is this an excpected behavior or a malfunctioning of the sensors ?
The reason that Obstacle Avoidance failed to prevent the colllision is that Obstacle Avoidance needs GPS to be able to work.
WIthout GPS, there is no Obstacle Avoidance. |
