Vibración en mi Dji Mini 4 pro
183 1 3-11 18:39
Edi_Col
Flight distance : 108560 ft
Colombia
Buenas noches, llevo menos de un mes desde que compré el DJI Mini 4 pro, lo he volado pocas veces, en las primeras veces todo funciona muy bien, pero esta ultima semana al momento de grabar se observa una vibración en la imagen continua que afecta por completo la calidad de los videos, cargué un video en youtube para que puedan ver el problema, sucede más cuando se graba en vertical, en horizontal ha sucedido pero no es constante.
https://youtu.be/fumaxURnhfQ?si=a4c9dmPhrJBNacll
Configurar la calidad del video en HD para poder ver bien lo que sucede.
Muchas gracias.
3-11 18:39
DJI Susan
Hi, there.You can do this as follows:
1. Check whether the gimbal knob has been removed when recording the video.
2. Check whether the aircraft is in S-mode (Sport). In this mode, greater emphasis is placed on flight performance. During the flight, when the aircraft attitude is too large, the gimbal attitude stabilization cannot be guaranteed. If the customer desires a higher view stabilization, we recommend recording a video in P-mode or Tripod mode (Cine mode).
3. Check whether has adjusted the aircraft EXP value. The higher the EXP value, the faster the aircraft speed. If the EXP value has been adjusted, go to [Advanced Settings] - [Reset Gain & Expo Tuning] to restore the EXP value. (except for Spark)
4. Please confirm whether the wind velocity was too strong in the field environment. If the wind velocity is too strong, the aircraft will vibrate. (One reference to determine the wind velocity is to check the place of video recording, and check the weather forecast to determine the approximate wind velocity in the environment.)
5. Try to calibrate the aircraft gimbal. (except for Spark)
3-11 19:19
