Ask for help. M3M multispectral images problem
211 7 3-16 02:55
fansbea42186
Taiwan
Hi everyone. I used DJI terra(V3.9.4) to process M3M multispectral images, and finished radiation correction by two plates, when I check the single-band images by Qgis, I found they are not normalized to 0-1, what happened 图片2.png 图片1.png
3-16 02:55
LV_Forestry
Flight distance : 4726654 ft
Latvia
Divide by 32768. middle of the 16Bit space
3-16 02:59
fansbea42186
Japan
LV_Forestry Posted at 3-16 02:59
Thanks my dear friend. I'm not the expert in this area, if I divided by 32768, the range of "result_NIR" will be like 0.001258-0.102582, is that right?
3-16 04:54
LV_Forestry
Latvia
fansbea42186 Posted at 3-16 04:54
It's possible. But from your screenshot with reflectance panel, i assume that something is wrong.
M3M is designed to be used with the Solar sensor and does a good job in that way.https://dl.djicdn.com/downloads/ ... essing_Guide_EN.pdf
Also be aware of that which is valid for both P4M and M3M :
Faulty Red-Edge Band | DJI FORUM
3-16 05:09
syqkyle
Taiwan
LV_Forestry Posted at 3-16 05:09
Thanks again for your posts. I read them all and tried some tests. I update the Terra to V4.0.8, and used the same data to processed again, the strange things happed, the values looks normal now. This just a part of my experient area, I will rebuild the whole area and see if it is ok.
3-16 08:44
syqkyle
Taiwan
Is there possible I can simply normalize the value to 0-1, or if I must divide by 32768 ?
3-16 08:54
LV_Forestry
Latvia
syqkyle Posted at 3-16 08:44
[view_image]
In the "update" raster, the values are normalized from 0 to 1 if you divided by 32768.
QGIS displays the minimum and maximum values by default. Feel free to adjust from 0 to 1 in Properties -> Histogram if you want to visually compare the image.
If you are doing computer analysis, there is no need.
3-16 11:35
syqkyle
LV_Forestry Posted at 3-16 11:35
Thanks my friend, I will follow your advice.
3-16 20:49
