LV_Forestry
Flight distance : 4726654 ft
Latvia
Sunister1 Posted at 4-12 08:43
Have you tried to post process your data using the free Emlid Studio program, then take the WGS84 .pos file it generates and convert the values to your projected model using a program like global mapper, then importing the converted .pos file into DJI Terra after you import the photos?
unfortunately this is not quite how you should proceed with a LiDAR. For photogrammetry this method is possible, yes. Although Emlid studio converts to ellipsoidal altitude only. So the problem remains the same.
The solution which consists of indicating a vertical offset remains the least worst. Use QGIS or something else to find out the geoid value at the location of your survey, and enter it in the box.
The story of the seven parameters, forget it, it's certainly someone who has no clue what it is or who hasn't understood the question, who answered that to you.
