fichek
Flight distance : 954216 ft
Croatia
When an USB device you're connecting to can be both a USB host and an USB peripheral, some Android devices have trouble negotiating which of the two (phone and goggles in your case) is the host device, so in that case you need the OTG adapter (USB-C to USB-A female you mentioned) on the side of device you want to be host (usually your phone, and you can usually tell if goggles become host because your phone will try to charge itself). Most phones can just use a straight USB-C to C cable though. Or if you have an iPhone older than 15, just use an USB-C to Lightning. |
