No Iris Control for Sony E Compatible Lenses on Ronin 4D
158 2 5-8 11:27
CDearolf
I have two different compatible e-mount lenses from Sony (FE 50mm F1.2GM and FE 20MM F1.8G) and I cannot get the Iris Control to work with either lens in the Ronin 4D. If I manually adjust the iris on the lenses, the correct reading shows on the montior; however, if I adjust the iris setting on the monitor, it does nothing with the lens. I have the latest firmware updates.
5-8 11:27
DJI Gamora
Hi, CDearolf. Thank you for reaching out. Let me forward this to our relevant team for further checking. I'll keep you posted.
5-8 20:38
DJI Gamora
Hi, CDearolf. Thank you for patiently waiting. Please see the feedback below:
1. Confirm whether the aperture ring of the lens is adjusted to A-speed before adjusting the parameters through the screen of the Ronin 4D body.
2. If it still can't be used, please provide a video of the operation process for further analysis.
5-9 06:34
