Don't use the stock case
406 14 5-14 03:21
mob5ter
Russia
This is the situation I encountered after the camera had been in the case for a long time. I think it's the magnets inside the case.
Unfortunately, I bought the camera in another country, and in my country there is no support for this company’s products. I'm afraid I threw a lot of money down the drain.
5-14 03:21
KlimaPic
Flight distance : 360115 ft
That case do you talk about? The DJI own case?
The rotaion issue may be a case for exchange by DJI. Did you rfase a support-case?
5-14 03:43
mob5ter
Russia
KlimaPic Posted at 5-14 03:43
That's right! DJI case that came with the kit.
I’m sure they will refuse me a warranty since I bought the camera while traveling, and in my country no one has heard of the word “warranty” or “support”
5-14 03:45
4wd
Flight distance : 545817 ft
I wondered what you meant about magnets as the case doesn't have any but the filters you can keep there do.
I thought the screen was a mechanical system though so aren't sure how it would be affected.
5-14 04:04
Fishycomics
So your thoughts on a Purchase, did you contact DJI on here and talked to them,  about your    problem.?
https://www.dji.com/support/repair
While cruising on International Waters,  we made a Camera Purchase , and was covered, so yes I say  contact  DJI.  keep the site posted
5-14 04:15
mob5ter
Russia
Fishycomics Posted at 5-14 04:15
Nope. I cannot select the region I need when contacting support, I cannot return to the country where I bought it.
5-14 04:26
Fishycomics
mob5ter Posted at 5-14 04:26
Wait for an Adminstrator of DJI to step in, and DM  you.Get with  someone in the COmmunity to step in on your behalf, and they can get with you that way.
To  protect the camera from further damage, may we suggest to tape the top/bottom from the screen  to move and the camera can be used in Portrait mode.
those are some options for you.  sorry that we can not mention  staff but get with a Staff member privatally on here and  see if they can further assist.
5-14 04:32
mob5ter
Russia
Fishycomics Posted at 5-14 04:32
I think I'll do that, thanks. To be honest, it’s a pity that due to the complexity of the design this led to similar problems; I didn’t even have time to try it out after purchasing it in the winter.
5-14 04:35
Fishycomics
you are very welcomed.
Regards FISH
5-14 04:47
mob5ter
Russia
I fixed it using the soft side of velcro, maybe it will be useful.
5-14 05:08
Fishycomics
mob5ter Posted at 5-14 05:08
https://youtu.be/21yoDluLCCA
that is awesome. glad you resolved the Issue. I normally do not flip the screen as much, that  is a greatfix.  pat yourself on the back.
5-14 06:07
johansenfoto
Flight distance : 1173379 ft
Norway
I'm glad you fixed it, good tip for other with same issue.
5-14 06:40
fichek
Flight distance : 1100308 ft
Croatia
Wow, that's such a weird issue, but interesting fix, good job.
5-14 15:01
DAFlys
Thats been a common issue but this is the first fix Ive seen for it,    great thinking.
5-14 22:12
Aavis
Flight distance : 328 ft
Finland
I did a great overnight stretch for the original case. It is a lot easier to take off but wont fall. Metals are super strong in the case and it is originally too tight. After leaving it to stretch over night it became super easy to use and it is not gripping the screen anymore like it did. Just put something heavy inside it that will give it a good stretch and you thank me.
You cant loose it too much. It actually becomes a bit back in some months but not at all like it was out of the box.
5-14 23:18
