Hello,
It seems there's a little bit of play on the tilt motor. Even if it's perfectly balanced it shackes on the tilt axis as if it has a few mm of free motion until the motor starts to work.
The problem is more noticable when I use 50mm or longer lens.
I'm using the latest firmware.
