Avata 2 - 4K 100 FPS
1402 8 2024-6-9
Chicago SkyCam
Flight distance : 1071959 ft
Hello,
I tried shooting in 4K 100 FPS after the latest update this weekend.  I received an error message shortly in to flight, SD slow record speed, ect and it stopped recording.  I was not able to record any 100 FPS footage, the card definitely had enough space.    I am using the recommended Sandisk Extreme card.  Anyone else experiencing this issue?  I was shooting in 16X9 to avoid h.265 files, I was thinking I would try 4:3 and see if that resolves the issue?
2024-6-9
Chicago SkyCam
Thanks in advance.
2024-6-9
A J
Flight distance : 15283773 ft
I use the Sandisk Extreme Pro 128gb and no issues my end
2024-6-9
DJI Natalia
Hi there,
thank you for reaching out.
Generally, this appears due to a slow SD card. If the original high-speed SD card is used, please try to format the SD card and try again. If the issue persists, please change to another SD card.
Before you proceed, kindly be advised to back up all the files on the said SD card before you procee.
Please use one of the recommended microSD Cards from the recommended list. You may check through this link here: (https://www.dji.com/avata-2/specs).
Should you have any other questions, kindly message us for an assistance. Thank you!
2024-6-9
djiuser_xnSMAFJtpo70
Flight distance : 320171 ft
Poland
Hi, I have no problem with my 4k100fps video, but when i try to create new project my 3 minutes video is 12 minutes in DJI fly app and it's slowed. Any solutions ?
2024-6-12
DJI Natalia
djiuser_xnSMAFJtpo70 Posted at 6-12 22:04
Hi there, thank you for reaching. Could you please try to format the SD card nd try again ? If the issue still persists, kindly share us a video example for our engineering team to investigate further and advise accordingly.
Thank you for your patience.
2024-6-13
Chicago SkyCam
DJI Natalia Posted at 6-9 19:27
Hi there,
It doesn't appear Sandisk is on the recommended list at all.   I guess I'll try one of the other brands on here as I've had consistent SD slow record and shut downs on the Sandisk
  • Kingston CANVAS Go! Plus 64GB U3 A2 V30 microSDXC
    Kingston CANVAS Go! Plus 128GB U3 A2 V30 microSDXC
    Kingston CANVAS Go! Plus 256GB U3 A2 V30 microSDXC
    Kingston CANVAS Go! Plus 512GB U3 A2 V30 microSDXC
    Lexar Professional 1066x 64GB U3 A2 V30 microSDXC
    Lexar Professional 1066x 128GB U3 A2 V30 microSDXC
    Lexar Professional 1066x 256GB U3 A2 V30 microSDXC
    Lexar Professional 1066x 512GB U3 A2 V30 microSDXC
2024-6-13
DJI Natalia
Chicago SkyCam Posted at 6-13 04:53
  • Hi there,
    Thank you for keeping us posted. Yes, please do try with the Recommended microSD Cards and update us on the results for us to assist further if the issue still persist.
    We are looking forward to your response for further assistance. Thank You
    2024-6-13
    djiuser_AWNAABlYBMnE
    Flight distance : 504337 ft
    Brazil
    Within this same subject, now with the launch of O4 Pro that offers 4K 120FPS. For me it's a disappointment not to have it natively in Avata 2... I just have to buy a custom drone and put the O4 Pro...
    1-9 07:42
