DJR
Flight distance : 417306 ft
Indonesia
Hi all...
Just got my avata2 last week. below is the timeline of the problem
- Charge all the deivces, turn on, activation and update frimware.
- Bring out to do the 1st run, turn on the headset, rc motion 3 and lastly avata2.
- Everything connected but when i press the lock button there is no reaction or beeping sound.
- Restart and retry still same issues
- Recalibrate the RC Motion 3 remote
- All buttons seem working fine except the lock button
- So what i do is i keep rapidly press the lock button, moving my hand up down left right and all angle
- At certain angle the lock beep register and the drone started the motor and hover
- And i flight as per usual and until low battery
- Land the drone using the joystick
- Change battery
- Same issues again lock button no reaction and beeping sound.
- Refresh all the devices frimware using DJI Assistant Software
- Try again, also same issues, no reaction and beep sound when press the lock button
- Somehow lock button have reaction if the RC motion at random angles
- Manged to fly about 3-4 times
- Send the avata2 to DJI Service Center
- Show technical the video of the problem
- Technical refresh the fimware
- Technical turn on headset and RC Motion Remote
- Technical press lock button, got beeping sound.
- Technical turn on avatar, press lock x 2 and drone motor start, press lock and hold drone hover.
- Technical repeat test a few times and it work like normal
- Technical explain probably software/firmware issues
- Bring Home
- Test today same problems all over again.....
Video 1
Video 2
Video 3
any expert can advise..
TIA.
update
Just received my FPV RC 3.
Link to the fpv headset and just fly as per normal like all my previous drone normally.
So for now if i wan to use the RC Motion 3 this is what i do.
-Turn on FPV RC3 1st
-Turn on RC Motion 2nd
-Take off using FPV RC3
-Once take off turn off FPV RC3
-RC Motion will connect
-Fly as per normal..
