M4P and Air 3 RC2 together
345 7 2024-7-23
Spikemixture
Flight distance : 159488 ft
Philippines
I have a M4p and bought a Air3 today .
I would like to fly both drones with both RC2 s.  Not at the same time
Like use one with both drones (not at the same time) and if the first RC2 gets low batt I can use the other.
When binding I cannot remember exactly but received messages on both saying something like I can use this controller 5 times before something gets unbound.
Thoughts ?
2024-7-23
DAFlys
You need to bind the controller to drone when you do the swap so that the flyaway coverage is valid.   This does need an Internet connection and just takes a few taps to do, you can do this as many times as you need.
2024-7-24
DJI Gamora
Hi there,
We are truly sorry for the inconvenience you are experiencing.
It seems your Remote Controller is not bind, kindly login DJI Fly app and follow the steps in the site to bind your device DJI Fly App Account and Device Binding
Each time you change drones, you have to go through the binding/linking process again. Please do check also on the firmware and app version, make sure both device running on the latest version.
We are looking forward to your response for further assistance. Thank You
2024-7-24
Spikemixture
Philippines
DJI Gamora Posted at 7-24 22:38
Hi there,
Why do I have to bind and unbind every time I swap?
No logic there. A RC can be set up with 2 drones. But 2 RC cannot be setup with the same aircraft!
And it has been suggested i must have an internet connection when doin this bind/unbind. Process.
That is not good.
It must be a firmware thing.
I would luke the techical reason why i cannot have 2 rc ready to go with a single drone. Even if firmware  cannot do it  then  a button in settings choses the drone. And does whatever it must do to switch to another aircraft.
Please don't tell me there is No way around this situation.  This ia D J I after all.
2024-7-24
DJI Gamora
Spikemixture Posted at 7-24 23:37
Hi there,
As mentioned, even if the same remote controller needs to be paired with different aircraft, turn on the controller and open the connection guide. Then select the corresponding aircraft model and either a firmware upgrade or switch prompt will appear on the app. Follow the instructions to complete the operations.
At the moment there is no workaround. Thank you for your recommendations. Please rest assured that we will forward your feedback to the related department for evaluation. In the future, we will optimize and improve the product or service based on user comments.
Thank you for your support and understanding.
2024-7-25
Spikemixture
Philippines
DJI Gamora Posted at 7-25 02:35
Hi there,
Thank . So there is a start . Let's hope the "related' department considers it ...
2024-7-25
DJI Gamora
Spikemixture Posted at 7-25 20:24
Thank You for your understanding and support. As mentioned your recommendation has been send to our related department. Stay tuned for the latest updates on the official DJI website or DJI Forum. Thank you.
2024-7-26
Spikemixture
Philippines
DJI Gamora Posted at 7-26 03:05
BTW Gamora, what happens after 5 x
2024-7-26
