NaT Travels
Hi all,
I've been having a little problem since the last firmware update with my mini 3 pro gimbal. When I increase altitude the gimbal automatically tilts down, the higher I go the more it tilts until it's pointing stiaght down. Then as I decrease the altitude the gimbal will tilt up until it's at its max up angle. I have tried changing it from follow me mode to fvp mode buts it does the same thing. In either mode I can adjust the gimbal with the wheel, but have to do this constantly which I never had to do before. All my firmware is up to date as of today according to the RC: App = 1.13.10, Aircraft = 01.00.0900, RC = 01.03.1700. I have calabrated everthing (gimbal, RC, imu, and compass)
To be clear when I am at a static altitude the gimbal operates fine, I can move to my hearts content in cine, normal or sport as long as I don't change altitude. The gimbal adjusts to drone yaw and pitch to keep the image level, the problem is only when I change altitude. So if i am flying up to a cliff or wall and increase the altitude to do a fly over the gimbal will drop, totally blowing the shot. It's not even like it is trying to maintain POI because the gimbal will just keep dropping until it's at max down. So when I take off the gimbal is centred, by the time I'm around 20m it's at full down, if I reset the gimbal it will be at full down again by 40m. If I then go down to around 10m the gimbal will be at full up (my altitudes are guesses because i don't generally monitor this).
I've being looking around and found a few almost similar problems but they seem to be more random, where this is like it's programmed to do it. Has anyone had this and if so were you able to fix it?
Thanks
