DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
The max flight altitude is 120 m. (*This limitation can be removed by unlocking the restriction.)
The details are as follows:
1. When DJI Neo is connected to a smartphone via Wi-Fi and the virtual joystick is used in DJI Fly, the max flight altitude is 30 m and the max flight distance is 50 m.
2. When DJI Neo is connected to a smartphone via Wi-Fi and under Mobile App Control, the max flight altitude is 30 m and the max flight distance is unlimited.
3. When DJI Neo is under Palm Control, the max flight altitude is 30 m and the max flight distance is 50 m.
4. When using DJI Neo with a remote controller, the max flight altitude is 120 m and the max flight distance is unlimited.
5. When using DJI Neo with Goggles and a motion controller or an FPV remote controller, the max flight altitude is 120 m and the max flight distance is unlimited.
I hope this information is helpful. Thank you. |
