JtrJr-UAV Pilot
Flight distance : 4341 ft
K,
The unfortunate part is that they will ultimately force you to upgrade anyway. Whether software or hardware, you'll have to upgrade. Go straight to 1.4.1 and make sure the bird functions there. Right now, if 1.4.1 works properly and you use Litchi, you're set. All advanced flight modes enabled. If 1.4.1 doesn't work properly, you're back to square one anyway. I wish I could figure out this "signal loss" issue. I'm starting to think the hardware is failing over time.
Good luck!
Jerry |
