DJI-Dave
Here are the step by step instructions Patrick.
Follow the process described below to upgrade the aircraft, remote controller and battery firmware.
Updating the Aircraft Firmware
Step 1- Check Battery and SD Card Capacity
Ensure the Intelligent Flight Battery has at least 50% power and there is at least 100 MB of free space on the SD card.
Step 2- Prepare the Firmware Update Package
1. Download the firmware update package from the official DJI website (http://www.dji.com/product/phantom-3/download).
2. Insert the SD card into your PC. Extract the all downloaded files into the root directory of the SD card. Remove the SD card from your PC.
Ensure the aircraft is powered off then insert the SD card into the SD card slot on the camera.
Step 3- Update the Aircraft
1. Ensure the remote controller is powered off and then power on the aircraft. Upgrade will begin automatically after aircraft is powered on.
2. It will take approximately 25 minutes to complete the firmware update. The camera status indicator will blink green and red to indicate the
upgrade is in progress and stop blinking when the update is complete with success.
3. Check the upgrade status by opening the “.txt” file that is automatically generated after the update. The update is successful if the text “result:
successful” is in the document or the camera status indicator shows solid green.Try upgrading the firmware again if the text “result: failed” is found or the camera status indicator shows solid red.
Updating the Remote Controller Firmware
Ensure the DJI GO app has been updated to v1.2.0 before updating the remote controller. The System Status bar in Camera View of the DJI GO App will flash several times if a firmware update is available. Follow these steps to update the firmware via the DJI GO App.
1. The remote controller has at least 50% battery level.
2. Your mobile device is able to access the internet.
3. There is at least 30 MB of free space on your mobile device.
Step 2- Download and Update the Firmware
1. Go to the DJI GO App > Camera View > System Status bar > Overall Status. Tap Download the firmware update package to download and update the firmware. Track the update progress from progress bar in the DJI GO App. The status LED on the remote controller will blink blue during update and blink green when update is complete with success.
Firmware update through the DJI GO app will not work with older versions of the remote controller firmware. If the firmware update fails, follow the instructions below to update the firmware using the traditional method:
a. Update the latest firmware package files from DJI official web site.
b. Extract all downloaded files into the root directory of an SD card or USB flash drive.
c. Turn off the remote controller, Insert the SD card into a SD card reader or the USB disk onto the remote controller USB port when remote controller is turned off.
d. Power on the remote controller and wait 60 seconds until the upgrade begins. Do not power off the remote controller during the update.
e. It will take approximately 10 minutes to complete the firmware update. The camera will sound a beeping sound and the Status LED on the remote controller shows solid blue to indicate the update is in progress. The Status LED on remote controller shows solid green and beeping
sound will stop if the upgrade is completed with success.
f . If you do not have a SD card reader, you may insert the SD card into the gimbal and connect the gimbal with remote controller to upgrade
Update the current remote controller firmware to v1.3.20 through USB flash drive. You will only be able to update the remote controller firmware through the DJI GO app from this point onwards.
Updating Intelligent Flight Battery Firmware
The Intelligent Flight Battery is upgraded during the aircraft firmware upgrade process. It is recommended to keep the upgrade package files in your SD card. The upgrade will start automatically after power cycling the aircraft.
Ensure there is only one firmware package file stored on your SD card.
Only storage devices that are formatted for FAT32 and exFAT file systems are supported for aircraft and remote controller firmware updates.
Ensure the internet connection of your mobile device is stable when downloading the firmware update package.
Turn on Airplane Mode on your mobile device before updating the firmware, as any incoming calls may disrupt the update process. Do not perform firmware update while the aircraft is still flying in the air. Only carry out firmware update when the aircraft is landed. Be sure to update the remote controller’s firmware to the latest version after you upgrade the aircraft’s firmware.
The remote controller may become unlinked from the aircraft after updating. Re-link the remote controller and aircraft.
Confirm the update results based on the blinking pattern of camera status indicator or gimbal sound. It is normal for the aircraft to sound or the LED to blink during the update process.
