Having just done a quick flight with the sun quite low and video the flight when i got back
i noticed the blades were interfering with the video it like a jellow but its not as when i turn the p3 away from the sun it had gone.
is there such a little sun shade bit like a little peak to attach to the top of the camera.
I know what you are talking about. Try ticking the camera tilt down 1 click (or two) and I know you probably tried that but it does help a bit. If you put anything on the camera filter ring that would stick out enough to help you then would see that in your shots instead. Are you using any ND filters? Or just the stock lens filter?
Hi thanks for the reply
ye i had a go at a tilt down it did cut most of it out but you can still see a slight jellow ( its the only way i can discribe it )
Im using standard factory fit camera no filters
