Are Air 3S batteries compatible with Air 3?
1587 4 2024-10-25
Leo Guerra
Flight distance : 6054019 ft
Brazil
Are the original Air 3S batteries compatible with the Air 3?
2024-10-25
DJI Natalia
Hi there,
Thank you for reaching out! The DJI Air 3S Intelligent Flight Battery is compatible with the DJI Air 3 aircraft.
For more information on the compatibility between DJI products, you can refer to the link here.
2024-10-25
Luis Diego Villalobos Araya
Costa Rica
DJI Natalia Posted at 2024-10-25 14:32
Hi there,
Can I use a Limeta MC331 charger (originally designed for Air 3) to charge the Air 3s batteries?
1-6 13:30
DJI Natalia
Luis Diego Villalobos Araya Posted at 1-6 13:30
Hi there, thank you for reaching out. Yes, you can absolutely use the Air 3s original charger with DJI Air 3 as it's compatible with each other. You may also check the compatibility using the link below in future:
[https://support.dji.com/help/con ... ;paperDocType=paper]
Thank you for your understanding.
1-6 14:55
fansde2bda7f
Flight distance : 3156 ft
Belgium
Beste , mijn. DJi mini 4 pro  kreeg ik binnen , met de controller en de vlucht ,  niet ontkoppeld  de naam van de vorige eigenaar staat er dus nog in .  Om een nieuw  herstel van deze drone te doen moet deze uitgelogt  zijn      hoevèel ,  x mag ik dit doen  en hoe  gedaan .    Ik heb zelf een dronebedrijf.
1-9 21:29
