levreault
Flight distance : 489111 ft
I've crashed twice in about 50 flights. Once i was trying to dive bomb the grass and flew a little too low. The other time I was flying thru a tunnel under a bridge, over a manmade creek. hit the side of the tunnel and my P3P ended up upside down under water. Took a week a multiple flights to regain my confidence. In both instance it was my cockiness that got the best of me.
If you go into flying your P3 expecting to crash, then you will crash
If you try to show off for other people, you will crash
If you don't know up from down and left from right, you will crash
If you think it would be cool to get a little bit closer to that tree, lake, car, building, you will crash
But in the end, if you start a venture expecting to fail, then you've already failed.
[Edit] Shaving this morning, thinking about my P3P and my tunnel crash and put two and two together. This was my problem; Its been a problem for many since the 1.4.010 update: While trying to fly thru a tunnel, my drone drifted left. And hit the wall.
