MaikR Posted at 12-10 02:39
Hi Mindy,
I know but the shocking and drifting at that point were not there due to wind or movement from my hand.... This was really an error. After restart everything worked again...
Hi, there
We totally understand how you feel.
It is recommended to set the aspect ratio to 16:9. When it is adjusted, RockSteady or HorizonBalancing can be enabled. When the aspect ratio is set to 4:3, EIS is not available. When EIS is off, the recorded videos can be processed for offline stabilization in Gyroflow.
Please try it and check if everything is better.
Thanks. |
