RC Noob
Help! I accidentally aborted a firmware upgrade for my P3 Pro controller and it wont work. Is there a way to reset this without sending back to the factory?
1. When i power it on, all controller lights come on and they stay
2. Phone can connect to the controller via DJI Go App but there is no prompt for firmware upgrade. If I go to about, it says v 1.1.5 for RC
3. I tried downloadinng v1.3 onto micro SD card (yes, formatted 3 times), and then tried to feed it via micro SD USB reader connected to the bigger USB port on controller. failed
4. Aircraft had been previously successfully upgraded to v1.4. I tried using the micro SD which has v1.3 in the camera slot of the aircraft, and connecting the micro USB from aircraft to the bigger USB port on controller. This failed as well.
5. I tried RC link from controller to aircraft just to see if it would connect, and it does not. My other controller (on RC v 1.3) connects to this aircraft just fine and has no issue
I think i need to somehow do a hard reset of the controller so i can reinstall some recent version of firmware on it either over the air via DJI Go or through micro SD. Is there a way to do this without sending this back to the factory?? Bummed.
