DJI Wanda
FfoSuy Posted at 12-24 21:27
Yes, the option to rename customer profile settings will be nice. It will also be nice if you can make changes to the custom settings (when you're in the custom mode), and saved it directly, without having to exit the photo/ video mode and then to the main menu to go the personal custom mode, and then select the mode to overwrite. (of course) I think you know what I mean.
Hello! After confirming, we would like to inform you that you can save a combination of camera settings (shooting mode, resolution, frame rate, stabilization mode, and white balance) as a set of presets. This allows you to quickly access your preferred settings during future shoots without needing to adjust each parameter individually.
The names for the custom modes on the Osmo Action 5 Pro (such as skiing, diving, surfing, air, racing, cycling, motorcycle, hiking, fishing, running, and Vlog) are intended for easy identification of different shooting scenes. However, you will still need to set the camera parameters yourself.
Here’s how to do it:
1. Set your preferred shooting mode, resolution/frame rate, stabilization mode, and white balance (manual or auto) on the camera page.
2. Swipe down and click on the Customize icon, then tap the + sign to save the current camera settings as Custom Mode C1.
3. To access this preset later, click the icon in the lower right corner of the camera page and select C1.
Please note:
- For the Osmo Action, Osmo Action 3, and Osmo Action 4, you can set a total of 5 custom modes.
- For the Osmo Action 5 Pro, you can set a total of 11 custom modes.
- The DJI Action 2 does not support custom modes.
Currently, manually renaming presets is not supported. We appreciate your feedback and will forward it to our engineering team for consideration. Thank you for your understanding and support!
