The horizon doesn't stay horizontal.
278 8 2024-12-17
Maddin-6616
Flight distance : 69301 ft
I have the following problem with the Pocket 3's gimbal:
After a few pans to the right and left, the horizon is rotated to the right by about 5 degrees. Now I have to center it again. It doesn't matter which mode I use. It's pretty annoying.
The Pocket is relatively new (around 80 days old) and hasn't been dropped or damaged.
2024-12-17
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
Kindly ensure the firmware of the device has been updated to the latest version. Could you please provide a video demonstrating the issue? You may upload the video to Google Drive or Dropbox and share the link here. I look forward to hearing from you soon.
2024-12-18
Maddin-6616
DJI Diana Posted at 12-18 02:42
Hi there,
attached is the link to the video... However, I noticed that it only occurs with the new FPV mode with an inverted T... although this mode is otherwise the most suitable for me.
https://drive.google.com/file/d/ ... view?usp=drive_link
2024-12-19
Maddin-6616
Hi there,
The latest firmware is installed!
2024-12-19
Lee_Haw
Kuwait
i have the same problem, when it happens i have to power off the osmo and re open it
2024-12-20
Maddin-6616
Lee_Haw Posted at 12-20 07:53
Unfortunately that doesn't help me... it's always the same behavior no matter how long it's been since the last restart or how often I start it.
2024-12-20
Lee_Haw
Kuwait
Maddin-6616 Posted at 12-20 08:24
did you tried to calibrate your osmo pocket 3 ?
form the menu  choose calibrate while its on a flat surface
see video :
https://www.youtube.com/watch?v=RqDOE3shYes
other than that it happens with me after a heavy usage and movement. they need to update it to re-balance to the horizon level on the (Roll Axis)
2024-12-20
Maddin-6616
Lee_Haw Posted at 12-20 08:34
see video :
Okay, I'll try that... It wasn't that long ago, but of course that's always highly subjective
2024-12-20
Maddin-6616
Unfortunately no other behavior...
2024-12-20
