50MP AEB's Not Applying Stops?
493 24 2024-12-25
Red Zeppelin
Flight distance : 34709485 ft
Merry Christmas all
Not been on the forums for a while as I lost my Air 2S to a critical battery failure, but just got an AIr 3S and took it for the first test flight yesterday. Generally loving the newer features, especially the free pano, but I seeme to have a strange issue and wondered if anyone else had experienced it or knows what might be causing it.
I took a few sets of AEB's, some at 12MP and some at 50MP. The 12MP versions come out as expected - with visually evident stops etc - but the 50MP versions have no visually evident stops in them for either the JPG or DNG versions. The EXIF data shows that stops are present but they aren't displayed in either Camera RAW, Lightroom or Photoshop for the 50MP files.
Does the 50MP support AEB or am I missing something fairly basic as I never had this issue in the Air 2S?
Thanks in advance
2024-12-25
DAFlys
Maybe try a few more tests,    sometimes DJI drones misbehave with the camera settings,  or forget them all together,       And dont forget each shooting mode normally needs the settings set for them.
2024-12-25
Red Zeppelin
DAFlys Posted at 12-25 02:58
Thanks mate - I'm sure it's something I'm missing, but just wondered if anyone had experienced the same thing.
Merry Christmas
2024-12-25
DAFlys
Red Zeppelin Posted at 12-25 04:48
Merry Christmas
Id do a test with the drone on a table, you dont need to be flying.   I doubt your doing it wrong to be honest.
2024-12-25
Red Zeppelin
DAFlys Posted at 12-25 04:50
Tried your suggestion thanks, but even more confused now
Lined up a few coloured objects, set to Pro / Manual and altered the exposure a little, then took 3 sets - 2 @ 50MP and 1 @ 12MP - the first set of 50MP had the visual steps I'd expect to see, but the second didn't and all looked the same, despite the EXIF again showing stops for all of them. 12MP was fine again.
Maybe I'll just stick to 12MP for AEB as I don't want to risk coming home from a shoot only for all the 50MP to look the same, but it's a shame because something obviously isn't right and I'd like to be able to utilise the 50MP.
Thanks for the feedback on Christmas Day anyway
2024-12-25
DAFlys
Red Zeppelin Posted at 12-25 06:50
They do say the 12mp are better quality as they are not using the pixel binning quad bayer sensor stuff.
2024-12-25
Red Zeppelin
DAFlys Posted at 12-25 07:45
Yes, I was just curious about the 50MP as Jake Sloan did an Air 3 vs Air 3S comparison video and seemed to think the 50MP on the S worked better than the comparative setting on the original 3.
Having edited some of the 12MP, I'm more than happy with them. Just seemed a bit strange that the 50MP was so hit and miss with AEB, but I've not been able to find anyone else having the same problem as yet so I'll keep testing
2024-12-25
DJI Natalia
Hi there, thank you for sharing your inquiry for the Air 3S. For models that cannot save HDR footage, the single HDR stitched photo and AEB footage can be viewed in “100MEDIA” of the aircraft or the microSD card. The shot photo will be marked based on the photo illustration corresponding to the “Camera Settings”, as shown below. The left is the final photo shot in AEB mode, and the right is a stitched photo shot in HDR mode.
Tap the corresponding photo to see more details:
The top-left corner of the AEB will be noted with “AEB (X photos)”.
Besides that, you may check the footage photos shot in AEB mode on a computer. You can see that the Tags are “aeb” in Properties > Details. The Tags for an HDR stitched photo are “hdr”.
I hope this information is helpful. We are always happy to help. Thank you.
2024-12-31
DJI Natalia
2024-12-31
Red Zeppelin
DJI Natalia Posted at 12-31 01:45
Hi. Thank you for the reply. I'm aware of all of this as I've been shooting AEB on DJI drones for 5 years now. My issue with the Air 3S is as described - at 50MP setting, the AEB stops are often not being applied to the images even though the EXIF data for the set shows stops as being present.
When shooting at 12MP, the stops can be seen as expected, but at 50MP they more often than not are not applying.
Thanks,
RZ
2024-12-31
Red Zeppelin
Screenshots attached showing stops in the EXIF data, but no visible stops applied to the 50 MP images.
2024-12-31
Red Zeppelin
2024-12-31
Red Zeppelin
I can't seem to upload the other two images showing EXIF data - they're cropping in for some reason - but they show the + and - exposures in the set of 3.
2024-12-31
Red Zeppelin
Last of the set hopefully.
2024-12-31
Red Zeppelin
And finally, compared with the 12MP versions.
2024-12-31
R3SKT
Flight distance : 740538 ft
Red Zeppelin Posted at 2024-12-31 02:24
Hi RZ,
I read your post and thought I'd go check what I have on file. I have a set of 5xAEB using the 70mm lens at 48/50mp resolution, and I DO have stepped exposure images to match. These were taken on 03/12/2024 before the last firmware upgrade. I'll have a further search and see if I have anything taken in AEB mode since updating the firmware and come back to you again. [edit] yep, set of 3xAEB with corresponding exposure steps, dated 14/12/2024, 70mm lens, 48/50mp setting.
1-2 03:51
Red Zeppelin
R3SKT Posted at 1-2 03:51
Hi RZ,
Hi R3SKT,
Thanks for taking the time to check this for me. The only difference I see is that while your AEB's were taken with the 70mm, mine were using the 24mm. Next time I get chance to fly, I'll try with the 70mm.
Thanks again
1-2 09:02
R3SKT
Red Zeppelin Posted at 1-2 09:02
Hi R3SKT,
Gone back a bit further, I have a set of 3xAEB exposures, 24mm lens, 50mp setting, and they are correctly stepped as expected. Here's a link to my Dropbox account. I've placed a zip file with the 3 .dng files for you to see. Excuse the subject, this was my first night flight with the Air3S and it was all a bit rushed.
https://www.dropbox.com/t/MmiQ7s06fgdComfs
1-2 09:31
Red Zeppelin
R3SKT Posted at 1-2 09:31
Thanks for those. Even more confused now
The EXIF on your samples go 0 step, -3 step, -2 step, whereas mine go 0 step, -0.7 step, +0.7 step??
Am I missing something in the settings? As far as I'm aware, only the number of frames (3 or 5) can be set for AEB, not exposure bias? Unless you were using a filter maybe?
All of that said, my 12MP examples also only have 0 step, -0.7 step, +0.7 step but they do show the steps visibly while the 50MP does not.
Thanks again
1-2 09:53
Greg Parker
Hi R3SKT,
Other difference is A3 vs A3S.
1-2 10:18
Red Zeppelin
Greg Parker Posted at 1-2 10:18
R3SKT's icon under his handle shows an Air 3S too? My 3S icon is yet to show for some reason, but that's what I'm flying so I assume the comparisons are valid.
Camera model in the EXIF data of his file's is also the same as mine.
1-2 10:58
R3SKT
Red Zeppelin Posted at 1-2 10:58
Definitely Air3S, no filter used, no adjustments to exposure bias, settings virtually as "out of the box"
1-3 00:44
Red Zeppelin
R3SKT Posted at 1-3 00:44
Thanks for confirming. I can only imagine the exposure bias is automatic and the variation is down to your shots being at night and mine being a fairly bright middle of the day. The Air 2s just did it automatically, but then I guess it didn't have the high res option.
I'll keep testing when I get time, but hopefully something will change otherwise I'll just stick with 12MP AEB's.
1-3 02:26
R3SKT
Red Zeppelin Posted at 1-3 02:26
I am very much still in the "trying everything out" camp to see what gives the best results. Took a 50mp/24mm single shot the other day, really impressed with how little colour noise there was, overall detail was pretty impressive given the craft is 50metres up, looking down whilst hovering and using a lens that you'd find in an iPhone.
1-3 05:00
Red Zeppelin
R3SKT Posted at 1-3 05:00
I was always delighted with the 20MP Air 2S shots - even long exposures of 3 - 4 seconds - as they had no pixel manipulation going on, so I was a bit sceptical of the 50MP on the 3S but I guess time will tell.
With 50MP AEB currently not an option for me for whatever reason, I guess I'll just try manually adjusting the exposure for a few shots. I'll be interested to see how they compare to the true 20MP of the 2S, but my upgrade was forced so I'll have to work with it either way.
That said, I am enjoying the functionality upgrades, longer flight times and quieter operation and if the UK weather ever clears, I might be able to get my second flight done
1-5 04:07
