IF your Camera IS Not Moving with the control wheel
11170 11 2015-10-6
rayrokni
Flight distance : 8139875 ft
If your camera does not respond to the control wheel!!!
go to gimbal advanced settings, there you will see 3 configurations. under each configuration you will see "Gimbal Pitch Smooth (0-30).
If this is set to 30 or near 30, the wheel will not have any effect. turn it down to around 20. The wheel should now control the gimbal pitch (or move the camera up and down).
This setting appeared after the app upgrade to 2.3.0 (IOS)
Hope it helps some of you experiencing non moving camera after update!!
2015-10-6
Joe Blow
Flight distance : 417149 ft
Colombia
Good catch Ray..........
2015-10-7
rayrokni
Joe Blow Posted at 2015-10-7 16:56
Thank you RF.
Happy flying
2015-10-7
ag0n
Flight distance : 700846 ft
Interesting.  My gimbal had no problem.  Running 30 on smoothing and 2.3.0.  Guess it isn't a problem on Android right now.
2015-10-7
DJI-Tim
As always, only useful advises  from Ray!
2015-10-7
rayrokni
DJI-Tim Posted at 2015-10-8 11:46
Hey Tim, thanks. It's probably an isolated problem but in case it is happening on iOS devices I thought it might help a few.
Thanks
2015-10-7
RedHotPoker
Flight distance : 165105 ft
My gimbal pitch wheel still works at thirty, they all do.
It's a setting for following a running snail... ;-)
Yes, it's an advantage to slow down the gimbal wheel.
But at that slowest speed it takes 50-50 vision to notice it crawl.
I must be an eagle eye. Hehe
RedHotPoker
2015-10-7
djiuser_9L5sVlc4eRvK
What app are you using? And would you know how to do this on a dji fpv drone and controller? Since update, only my 3 position switch works with camera gimbal. Not the wheel...im using the Grey dji fpv controller.
2023-10-12
DJI Paladin
Flight distance : 318 ft
djiuser_9L5sVlc4eRvK Posted at 10-12 20:43
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please perform the Remote Controller Calibration via the Goggles and check whether the sticks and the dial (wheel) are working? Make sure to update the drone, goggles, and remote controller's firmware to the most latest version to avoid issues. Thank you for your understanding.
2023-10-19
Jacksonsmith023
Pakistan
If your camera isn't responding to the control wheel, check the gimbal advanced settings. Look for "Gimbal Pitch Smooth (0-30)" under each configuration. If it's set to 30 or near 30, the wheel won't work. Adjust it to around 20, and your wheel should control the gimbal pitch (camera movement up and down). This setting came with the app upgrade to 2.3.0 (IOS). Hope this helps if you're experiencing camera issues after the update!
2023-11-6
ANORD LYIMO
Tanzania
My drone spark dji its wifi does not show up so as i can conect to my mobile
2-17 23:54
DJI Paladin
ANORD LYIMO Posted at 2-17 23:54
Hi there. Thank you for reaching out and we do apologize for the trouble. Please make sure to input the correct password when connecting via WiFi. You may find the WiFi SSID and password inside the battery compartment of the aircraft. If the issue persists, please try to reset the WiFi SSID of the DJI Spark and check if there are changes to the issue. You may refer to the tutorial video posted below for your reference. Please keep us posted. Thank you.
2-18 04:04
